Stagezilla, i could have helped you a long time ago but just starting reading your stagediary today. 260RS and 33GTRS have differant length rear drive shafts. I think from memory GTR are to short. Its been a while but i built a Stagea just like you a few years ago in Japan. The rear end in short gave me a lot of headaches. Also if you use 33 GTR rear hubs as you want to the shocks become the next issue. First of all 33GTR and 260rs rear shocks are diff. 260RS are longer, not such a problem just buy 260RS rear shocks, umm The strut tops are diff diameters. You may get away with pillow mounts but from experiance the 260 RS std strut top is bigger than the RS4 std one and fows on the inside of strut towers. Front are same just diff damper rates. Also if your Stagea has no rear hicas you can swap the bush (non hicas stagea) to the gtr hub (which has a pressed in balljoint for the hicas tierod end to attach to) and your stagea non hicas arms will bolt straight on. I used a whole 33GTR diff, hubs, axles and 260rs rear shocks. The axles were to short. I even tried nissan president shafts as they are same spline and dia as gtr. The autech 260RS rear xmember is diff to allow the hubs to sit closer to the diff for tyre clearance. Sorry to write so much any questions glad to help.
  • Replies 40
CORRECTION Sorry Stagezilla. R33 GTR (non vspec 4/95~12/97) left and right drive shafts are same as 260RS (11/97~8/98) drive shafts. Just went to garage and check my notes, its starting to come back!! When i put them in that was what i thought "WTF there to short" . The 260rs rear cradle is basically norrower (not much but it is) than the rs4 cradle. I even tryed a 33 gtr rear cradle complete with hubs,shafts etc (i had a written off 33 gtr to swap parts around if your wondering where did this guy......), going this way stuffs up the rear shocks angles. Anyway you can make it work this is Aus afterall. Half shafts also same, at the time i thought they may have used differant length half shafts but they don't. I had a problem with hand brake cables length also. Can't remember were, think when putting GTR rear end in??? Don't think youll have any problem. Hope you make it work.
hey argo thanks for the detailed info from a person who has actually done it ;)
yes we have removed the hicas bar and put the stagea bush end to bolt up the stock stagea arms, we have test fitted the hubs on which are fine but we aint bolted the diff centre in and tried the axle lengths which i hope is ok :whatsthat
im using the top arms from the gtr with the round top on em that surrounds the shockies, and then the other 2 arms are stock stagea ones.
u r getting me worried now hehe :confused: well considering we did the entire conversion at home it shouldnt be too much hassle.. i hope :whatsthat
ill let you know how it goes
Brad
well argo is correct on the axles being too short :whatsthat
they are about 100mm too short dammit, so how did u solve the problem then????
one option is too get axles lengthened but maybe theres some easier way?
cheers again mate i believed ya but i had to check for myself :innocent:
thanks
Brad
  Burns said:
So dose that mean that the Stagea has a wider track than the GTR.  How dose it compare to a R33 GTSt?
I tried to fit a R33 GTS-t sway bar on my Stagea but the rear sub frame was about 50mm to wide for the mounts to line up.
ok well i been measuring things up and trying a few ideas and heres my findings ;)
stagea track is wider than the gtr (and gtr axles are about 80mm too short compared to stagea ones)
tried a gtr r32 swaybar on the rear and it DOESN'T fit so thats buggered that idea :whatsthat
well the real good news is i recently got sent a axle to replace to stagea one and found out its heaps fatter and bigger unis etc so i compare to gtr one to the one i got sent and the one i got sent is EXACTLY the right length to fit the stagea with gtr diff which is bloody awesome and a stroke of luck as its actually a GTS4 axle which is same larger size as gtr but just 80mm longer :)
so that is sorted which is a good thing, just waiting for another gts4 axle for the other side now :uh-huh:
cheers guys for all the help
  StageZilla said:
ok well i been measuring things up and trying a few ideas and heres my findings :)
well the real good news is i recently got sent a axle to replace to stagea one and found out its heaps fatter and bigger unis etc so i compare to gtr one to the one i got sent and the one i got sent is EXACTLY the right length to fit the stagea with gtr diff which is bloody awesome and a stroke of luck as its actually a GTS4 axle which is same larger size as gtr but just 80mm longer ;)
Some questions;
Is that an R33GTS4 axle or an R32GTS4 axle?
The GTR axles that where too short, where they R32 or R33?
:D
gtr axle was the r32 and im unsure about the gts4 one but ill find out very soon and let u know :) (but argo said r33 gtr where too short too )
im assuming the gtr has a lesser width track at the rear to fit bigger tyres under the gaurds maybe?
im wondering how the front driveshafts compare to gtr ones then?
but the gtr diff housing and stagea diff housing are identical except mounting points on top for attessa pumps etc, so we put the gtr lsd stuff in the stagea housing.
so its all bolt in from here thankfully, no custom length driveshafts to be made :Party:
thanks
Brad
hi, the R32 GTS4 diff ratios are RC43, 4.3 so they 'should' work.
I have measured up a lot of stuff off my GTS4 against a friends R32 GTR which is the same month/year as my GTS4 and they share most of the bits(obviously dif ratios (and lsd type) and gearbox ratios are different, driveshafts are same diameter(fronts) swaybars, suspension links and bushes are same even checked on the Fast systems and they use same part numbers. that part matching module in fast is really cool, seeing what cars use the same parts as the skylines!
p.s. I always thought the Stageas were real close to the Skylines, obviously they are not designed for the same market and it makes no real sense building a family 'sports' wagon with components that can handle massive HP upgrades. The jap prices I have seen for very new Stageas always seemed too cheap to me for a car that I thought was basically a 'Skyline without a boot'. I suppose if you want a tough as nails stagea Nissan will happily point you in the direction of a 260 RS.
  MrMayhem said:
pioneering is the most interesting
lol
Brad I have big ARC front and rear sway bars for the stagea rose jointed........  come on down
ill take em :uh-huh: ill give you a ring today mate and might even return your brakes and swaybar haha :Pimp2:
thanks mate
Brad
  • 1 year later...
i need a little more light on this subject as ive removed the rear cover then removed the to bolts in there but dont know what to do next could someone please explain this to me more clearly? thanks
  • 2 months later...
  • 4 months later...
im a little confused.
exactly what parts of ur rear end did u replace with gtr??
u said u used stagea housing does that mean these "longer axles" are the same as std stagea axels??
will they bolt straight in to any stagea or do i need a bunch of gtr stuff??
it was along time ago now and i forgot alot of info, but the stagea axles snapped and i put in a gtr centre in the stagea diff housing, as they are both r200 diffs, but i used the stagea housing for ease of mounting attessa pumps etc back in as normal. I added gts4 axles and one long one fit the short side of the stagea and the long side needed another 40mm added onto it to make the length fit. I dont know if it was a r32 or 33 gts4 before anyone asks lol. The gts4 axles are same as gtr in thickness and uni joint size, but alot longer. GTR axles wont fit as they are wayyy short. Thats about all i can add on the subject as i didnt experiment with any other parts at the time.
    • Any difference in induction noise?
    • If I got a dollar for every flipped commuter missile I've driven past I'd have two dollars   Some people get into wild adventures on the road and I doubt it's gender or ethnicity specific. I'm just glad I don't usually drive during peak times.
    • Just got the car back and gave it a good run back home Power wise, whilst it only made a extra 5 killerwasps up top at 7200 rpm, it made more power everywhere from 2500 rpm and kept pulling much harder all the way, to the point of me relearning when to shift so I don't hit the 7200 limiter, with the old intake it seemed to take alot more time to rev out, and, throttle response is also much improved  As I didn't want to remove the bumper every time I serviced the air filter (basically every aftermarket and fabricated CAI has the filter behind the bumper) it currently has a hektic exposed pod in the engine bay sucking in hot air, this will be rectified shortly after some some of my CAD (cardboard assisted design) for a alloy heat shield feed by the OEM intake tube behind the bumper, this will cop some wrinkle black paint, as well as the intake pipe for that totally OEM look... The only fly in the ointment was that the OEM "strut" brace doesn't fit over the rear runner of the new intake with the 2.5 engine is in the engine bay, as the 2.5 raises the engine up by 20mm, it's not a war stopper, and I didn't notice any difference without it in some twisties, but....... MX5 Mania is bringing in some GWR "fancy pants" braces that apparently do fit, if it bolts up I'll grab it, it is also stiffer than the OEM one, which is a bonus All in all I'm happy with the outcome      Fancy pants "strut" brace that gives the required clearance      This is where the clearance issue was, the GWR extends out past this
    • Well, I'm back from the dyno today. Some things do partially make sense. The pod filter/airbox delete picked up between 6-10rwkw on 98 - because heat soak does kind of affect things and there was playing with tune/timing/AFR. Oddly enough, the car was running much leaner than before. So lean it was audibly pinging on the dyno which I got video of:   70de0dd5-2099-4a71-8b10-6fc833fb9d59.mp4   We're talking going from ~12.7 in the past to the first run being at like ~14.0. It is now tuned to ~12.5 on the Dyno, which correlates to about ~12.1 on my wideband in the car. These matched last time, which is very odd. The dyno plots only show the dyno's reported AFR - should be last time, yet now it no longer agrees and was way leaner. Nobody has an explanation for how a pod can make the car run notably leaner, yet not really give any more power when you add fuel in. A few different types of intake design were tested:   94c22c34-7991-4902-af85-314b5f5bf352.mp4   There was no difference other than IAT with the pod sticking out of the bay. The pod sticking out of the bay (but connected) is actually still warmer than what I usually see on the road. Removing the pod entirely lost about ~2kw. But to be fair, all of the runs could be argued to vary by that amount when temperatures climb etc etc. It's safe to say that the filter isn't causing any restrictions of any note that can be reasonably altered in any way. This is in line with what I'd expect given the Engine Masters testing. 323KW on 98 and ~335KW on E85 is actually a pretty solid result, up about ~45kw from 99% of LS1 cammed combos, with generally much larger cams/exhaust etc as well. It is after all up 42KW (98) and 54KW (E85) from before. +10KW from a pod and removing the box is cheap as chips compared to what the head work cost per kw No, I did not get to drop the exhaust and test. When it comes to exhaust... it all just seems to change frequencies and cost or gain 2hp here or there. I don't realistically think I'll drop this to test it - because there's not much else I can really do about it/route it any other way/make it bigger/just bought mufflers. Engine masters beat the hell out of headers with a hammer to deliberately kink them and didn't lose power at all, I sincerely doubt that going larger primaries would help. If it were even possible for clearance/conversion reasons... which it's not... I may throw the E85 in there at some point and do a drag run to see what MPH it traps for science. It isn't lost on me that ~320kw Skylines do trap about the same MPH that ~370kw F-Body/Corvettes do in the USA for the same  or similar weight. (122-125mph). Of course, if I go there and trap 104mph or something then I'll just 'accidentally' have an accident on the way home from the drag strip and buy a M4.
