dudes,
i am getting an R32 GTR soon, with hopefully around 230 - 250rwkw. Now there are quite a few WRX STi's getting around my town (Mildura) and I wanted to know how I would go against one. Im fairly certain they are all pretty stock. Maybe an exhaust, BOV here and there, but nothing serious.
How would a GTR go against them?
https://www.sau.com.au/forums/topic/7692-how-would-a-gtr-go-against-a-sti/
  • Replies 45
Originally posted by Ethan_R32
dudes,
mate with that kinda power at the wheels an STi would be lucky to sniff the fumes from ur exhaust let a lone pose any sort of problem lmao
most hi-po STi's are around the 300kw @ the fly mark and they are very rare... most of the drivers a re yuppies that just buy them for the name and dont spend much on em. (bit of a generalisation but has a fair bit of truth to it)
My mate has a stock STI.
I have an R32GTS-t with a pipe, K&N, BOV and 235 tyres with adjustable sports suspension, and I think my car makes about 10psi of boost. His car definitely has more power than mine - he gets out of corners quicker and we have about matched driving ability..... BUT, in a fang going up into the mountains, he only made a couple of hundred metres on me over several k's. His tyres are stock. My car seems to handle better - you just can't beat the 4 wheel steer in the twisties.
GTR? I think you'd see em off.
(And by the way, he has 70K on his car, is onto his second box and the synchros are not so hot on this one either - it will probably need work in the next year or so. They do tend to have box problems.)
Woooohoooo...
Good one Andrew, your GTR is on it's way - well done :mad:
If the STi's are anything like the WRX's, if they dump the clutch too many times they be leaving their clutch and gearbox behind them at the lights :bahaha: :bahaha:
I really can't see you having a problem.
You might just end up having one of the fastest cars in your town :uh-huh: :uh-huh:
J
inark: the STI's have 300kw? Or is that the pretty heavily modded ones?
I thought that I should be able to beat them, but I remember racing an MY00 in my GTS-T and he cained me by a fait bit.
Jay: hey mate! Yeah finally got my dream happening, I just cant wait until it comes! Im even having weird dreams about 4WD and so on. Like taking off and this magical thing happens and the 4WD shoots me forward....... weird........:mad:
ive been on a mountain run with an 02 STI. Very good poise through the corners, it can make a young rough driver can look very good but it seems to be a relatively slow car, especially in a highway roll-on situation.
nice car, but :shake: to STI.
Jay: hey mate! Yeah finally got my dream happening, I just cant wait until it comes! Im even having weird dreams about 4WD and so on. Like taking off and this magical thing happens and the 4WD shoots me forward....... weird........:(
Bahahah - you know that your a a true Skyline lover when your dreaming of them.
But seriously, you'll have yourself a weapon of a car Andrew. After reading that link above, the Australian delivered STi's only have 195kw at the flywheel (that is stock), and don't come on (serious) boost untill around 4,000rpm. So for them to do anything serious they have to dump the clutch.
And that link actually said that they don't know how Subaru come up with tha 0-100 time of ~5.5 sec cause they could only manage a low 6 sec. And a stock GTS-t does a mid 6 sec 0-100 !!!
Once you get the launch down pat I think your going to have some fun with the STi's :D :uh-huh: :uh-huh:
:burnout:
The ones in Japan have had the updated motor for a couple of years with more power. Its probably just that motor that they're finally brining to the local version, which missed the update for a couple of years. Least they look better again with the revised front.
Jay: yeah I still reckon most of the guys around here who have bought them, just want to look good, and to say "I have an STI". Seriously, all the ones ive seen, have been driven by the "fully shik" blokes who got their parents to buy it for them. Not saying all WRX drivers are like this, but the ones Ive seen.......:(
14 1/4 mile? HAHAHA nuthin! I would have been able to beat one in my old "T".
Im hoping for 11's.
Guest too quick
Originally posted by Jay95R33
Damn - with that sort of times, your eyes are going to be sucked into the back of your head !!!
J
So J,
what would happen to Kermi's eyes that pop out of his head... but i'm sure he'd enjoy the ride as much as he appears to be having fun now!! hee hee:uh-huh: M
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
