hey guys just a quick question
can a rb25 garbox be bolted to a rb20
does anything ahve to be moddified or is it a direct replacemant????
cheers
mines screwed was going to get rebuilt but have heard rb25 boxes are tougher is this true?
matt
https://www.sau.com.au/forums/topic/76973-rb25-garbox-on-rb20/
well im talkin bout putting the rb25 box in a silvia that allready has a rb20
so i hope it lines up
as for tail shaft have heard rumours that the CA shaft and box where diff the SR oh well ill have to speak to a jap wrecker or something??!!
i don't know that they do or not, my mounts are about 2 inch's rearwards of the normal CA box mounts, but my engine sorta sits a bit lower and further back also.
I got RB20 box (was told it was 25, till i took it out) babow!
I can't see why they shouldn't fit, as VL's run basically an RB20 box, and VLT's run same as RB25 i was under the impression??
Have you looked into getting it rebuilt? If so can you give an idea of price and parts repalced?
Mine is holding in there ok after two nights of drag racing, a drift day and 8 or so track days with +215rwkws. Its still going well with good oil, so im thinking its up to the power ive got, but it is a 180,000km gearbox that did about 3,000kms of track work with the std turbo.
So basically dont want to go to the expense and added weight of an RB25 box if there is a viable alternative...but suspect ill end up with an RB25 box.
Roy,
Your running that Castrol 75/90 in your box?
I've used the above.
I figured the slightly thicker warm oil will help my poor little rb20 box behind the rb30.
For the first few hundred km's the box was actually perfectly silent again. Its gone back to its usual loud input shaft bearing noise.
Yeh Castrol Syntrax 75W/90
http://www.castrol.com/liveassets/b...90_B1278983.pdf
The box is the same old same old when cold...it never has been brilliant. But once i have done a few kms it shifts fine, and it does feel better then the Fuchs that was in there.
Funny thing is when at the track, and when it must be pretty hot, it shifts like a new box, and for the rest of the afternoon/home etc it shifts brilliantly. After it has sat overnight and its 100% cold again it reverts back to same old same old:(
So it would seem to be a bloody good oil, but perhaps suggests it never really get sup to the optimum temperature/viscosity putting around on the street...well for my g'box anyway
When cold I honestly found mine shifts a little better with the VMX 80 I had in there, it also had a tube of that Nulon G70 stuff so its not really a good comparison.
I have found that after a few changes it shifts like new again, no notchyness.
Lightened flywheels makes a noticable difference to high rpm shifts. I will definately be going back, BUT this time, one with a replaceable insert. The ceramic will rip a molly item to pieces.
Roy,
Here is a link that works,
http://www.castrol.com/liveassets/bp_inter...90_B1278983.pdf
I might try that oil in my box when i put it back in, had a tendancy to crunch into 4th (woulda thought 2nd or 3rd be first to get noisy).
On the topic what oil do you run in yer diff?
i guess my only prob with my box is it just doesnt like second
round rev limit and bot 500rpm before
that is all its just annoying trying to hold a slide then pop second and it s just like
"he ha hmmmm get in there you son of a bi........."
i lose all power cuz i have to come off throttle
same in a straight line im sick of making a come back in third cuz i cant grab second fast enough
it makes the car seem slow its like ppl are laughing at me (V8 tosses where i live)
till ill blow past breaking traction in third (eat that bogans)
but yeah i just wanted to know if they can replace rb20 boxes
if its cheaper to get rebuilt then i will but it dont matter to much because i have to take all engine and gearbox out as one anyway (damn silvia tunnel to small)
and innisane
dont worry to much bout weight
my car with 3/4 tank fuel spare tyre all interior only weighed 1220kg on the weigh bridge
a standard 180 with all HICAS and all options weighs nearly 1240kg
so 20kg in a box wont matter to much
cheers
matt
    • (it is a brand new ported mellings pump) I suspect the lack of pressure is due to the leak. It was *not* that low in other logs of oil pressure in the past. It wasn't that hot either, but not far off.
    • Would a Mellings oil pump be a viable option  From my time with a LS, and talking to tuners and LS specialists, the "weak" OEM oil pump is one of the first things they recommend to swap out if I was going to give the engine any high RPM I opted for a Mellings high volume, with the high pressure springs and I never had a issue with it Cost wise they are not expensive in the scheme of things
    • Just bought a 2002 Stagea 250tRS VR-X Four AERO VQ25DET and spent the last two weekends cleaning and detailing it.. still have to do the wheels and the engine bay but the rest of it came up nice. Imported 2011 to S.A. and I'm the third owner since it was imported. I met the guy who brought it over, he went to Japan and picked out the car, bought it and ordered the wheels. He also gave me a list of stuff he did to the car with receipts. Coil overs (I have the original springs), 3" exhaust from the dump pipe back no cat, Custom dump pipe,(I have the original exhaust), Plenum spacer, 18" custom Work XSA wheels (need restoring, I've made a start..), Shift kit put through the 5 speed tiptronic auto, TV and menus/screens changed to english, Australian DTV tuner installed in rear. I've just had four new discs and new pads as well as all the fluids including the brake fluid replaced. I have all the receipts for the last 15 years and the import papers in a nice folder. Car looks great, goes like hell but fuel economy is not a thing lol.. pics next..
    • I ended up in this rut again lol, and used a shit ton of filler. One thing I can't understand is, even after using a big long block and going in long X pattern strokes, I always end up at bare metal again with no filler, and my repair started at one end of the door and now I've chased my tail to almost the other end of the door. I was thinking of hitting the panel with a hammer where it might be a high spot and making everything low then filling it, I did this on a small section on my other door by mistake and I think I fixed it lol. Is this a bad idea? The other thing is with guidecoat, whether it's the powder or spray, after I sand all the guide coat off, it doesn't reveal anything for me in terms of high spots and low spots and makes it especially hard when it's bare metal (at least in powdered form), am I doing something wrong here, or likely a high spot I keep going over and creating valleys? Lastly, stupid question but, is it possible that after sanding if I only sand over the filler area where I know to be a dent that it's impossible for me to dig into that dent? Unless there are other problems which I missed.
