hi guys im looking at buying a garrett gt2535r turbo, but am unsure as to the specs. im sure that it bolts straight onto my stock manifold, and is internally wastegated, but the my question is, is this turbo a good upgrade, and how much power will i gain? any help will be great..
thanx in advance
https://www.sau.com.au/forums/topic/77094-garrett-gt2535r/
i found these using the good ole search button.
highly likely that there are more. Give it a shot i reckon
doesnt answer all your Q's i dont think, i aint really read them.
http://www.skylinesaustralia.com/forums/sh...highlight=2835r
http://www.skylinesaustralia.com/forums/sh...&highlight=2835
also searching the RB25 Dyno results thread - good idea
https://www.sau.com.au/forums/topic/77094-garrett-gt2535r/#findComment-1410935
thanx for the links but they werent really wat i was after, i kind of want to know if this turbo is a good upgrade for r33 gtst, and if not wat would be...
Sorry, but you haven't provided enough information to give a reasonable answer. What are you going to use the car for?
What is your power target?
What other mods do you have?
What other mods are you planning?
With that sort of info there are plenty of opinions that will be shared:cheers:
https://www.sau.com.au/forums/topic/77094-garrett-gt2535r/#findComment-1412263
sorry my bad...
current mods: FMIC, POD, 3" dump, high flow cat, full zorst, boost controller
future mods: PFC, new turbo, injectors, fuel pump
hoping for anything up near 200+rwkw
thing is i found a garrett gt2535r but i dont know anything about it... need some advice thanx guys
https://www.sau.com.au/forums/topic/77094-garrett-gt2535r/#findComment-1412796
sorry my bad...
current mods: FMIC, POD, 3" dump, high flow cat, full zorst, boost controller, BOV
https://www.sau.com.au/forums/topic/77094-garrett-gt2535r/#findComment-1412798
HKS GT2535 - 340 PS Output
COMPRESSOR:
-Wheel- 56 Trim - 51.6 Inducer / 69.0 Major
-Housing- 60 Inlet / 50 Outlet - 0.60 A/R
TURBINE:
-Wheel- 76 Trim - 53.8 Major / 47.0 Exducer
-Housing- GT25/T3 inlets / Outlet specs:
Internal GT25 outlet; 0.64, 0.86 A/R
Skyline Type; 0.64 A/R
HKS GT2540 - 350 PS Output
COMPRESSOR:
-Wheel- 46 Trim - 51.7 Inducer / 76.2 Major
TURBINE:
-Housing- T3 inlet / Internal Skyline Type oulet - 0.64 A/R
Hope these helps. Im goin for a HKS2540. Check out www.hksusa.com
https://www.sau.com.au/forums/topic/77094-garrett-gt2535r/#findComment-1415060
Trust33, yeh thats ok, im sure it is rated a little hiegher.....not 100% though
Performance werkz thanx for the info, so the gt2535 has t25 internals? im confused now, i have a choice between the 2, either gt2535 or 2540 but ive read that the 2540 is a little laggy due to its mismatch!!!!any comments would be helpful
again thanx guys...
https://www.sau.com.au/forums/topic/77094-garrett-gt2535r/#findComment-1415618
hey guys just realised that the R versions are the t25 flange, i think, not sure but i found a table from bd4s website, and all the r versions have t25 flanges, and the normal gt models are skyline based with t3 flanges
https://www.sau.com.au/forums/topic/77094-garrett-gt2535r/#findComment-1415631
mass4,
yup...i was wondering why you are goin for a t25 flange while ours are t3 flange..
anyway what u mean by 2540 is a little laggy duee to mismatch..
one more question guys..if i would like to mount my turbo on the top i need a top mount
manifold rite?
thanks!
https://www.sau.com.au/forums/topic/77094-garrett-gt2535r/#findComment-1416321
    • Yes, I know🙄 but the sequential is not in my budget... don't want to reduce power neither, so looks like I'm stuck in the rabbit hole🤣
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
