We still have a couple of spots available for DECA but as a reminder entries close on Wed night for this.
Also - if there was anyone wanting to come up to spectate or for the socal side of it was could use a few people to help out with marshalling / time keeping etc. Anyone interested in doing this please PM me or better still come to the Club night tomorrow night.
https://www.sau.com.au/forums/topic/77577-deca-entires/
Have also decided to ONLY help-out/spectate, just can't afford the extra expenses associated with this event :(, as i still have more/other expences to pay for.
Committee ppl, i will catch up with all of you tomorrow to discuss other areas that i could help with, and my mate (Malcolm) may also be interested in helping out.
https://www.sau.com.au/forums/topic/77577-deca-entires/#findComment-1420009
Yeah no worries West. I've marked both you and Hung down as coming.
:D
Good morning, i fax both entries forms with receipt numbers just then. Wired it through last night so i asume won't be in till later.
One problem is Hung hasn't got his member's number and so is cams. Can you please fill it out when you get the fax? About Hung's LS2, can he pay on the day?
Cheers
(ps: i fax them twice cos' the stupid fax machine at work didn't work properly so i was just making sure :uh-huh: )
https://www.sau.com.au/forums/topic/77577-deca-entires/#findComment-1424934
    • Even more fun, leave all the ADAS stuff plugged in, but in different locations, hopefully avoid any codes!   And honestly, all these new cars with their weird electronics. Pull all the electronics out Duncan, and just shove an aftermarket ECU and if needed a trans controller in, along with a PDM. Make it run basic but race car styled!
    • To follow up a question from earlier too since I had the front bar off again (fking!) This is what is between the bumper and the drivers side wheel And this is the navigator side, only one thing but its a biggy! So basically....no putting coolers in the wheel arches without a lot of moving other stuff. Assuming I move to properly race prepping this car I'll take that job on and see how the computers respond to removing a whole bunch of ADAS modules
    • So I prepped the car for another track day on Wednesday (will be interesting to see coolant temps post flushing out and the larger reservoir, with a forecast of 3-14 being 20o cooler than last time I took it out). Couple of things to mention; since I am just driving the car and not taking a support vehicle, I took the rear seats out and just loaded the back up Team Trackday style. Look at all that space! To cover off removing the rear seat....it is weird (note the hybrid is probably different because it wouldn't have folding rear seats) Basically, you remove the lower seat base, very similar to a r series but it is a clip that pulls forward to release the base rather than it being bolted down. Easy Then, you need to remove the side section of the rear seat on each side. There is a 14mm head nut at the bottom of the side piece, the it slides upwards off a hook at the top to release; you also need to unhook the seatbelt from the loop at the top. Then the centre piece is weird. You need to release/fold the seats forward with the tab in the boot on each side From there, there are 2,x12mm headed bolts holding the rear of each seat to the folding bracket, under the trim between the rear seat and the boot (4x christmas tree clips there, they suck). The seat is out but you can see where the bolts attach to the bracket
