Unfortunately my sunroof came flying off on graham farmer fwy, doing a few flips and a jump, committing suicide on the front of a bus, thank **** it wasnt a car!!!
If anyone knows where/how to get this replaced pls let me know asap. (I think i need to get one cut- i've had no luck with wreckers etc).
It was not the original sunroof, it had been replaced once before (before i owned the car and I dont know who replaced it) and obviously not done properly.
Dangerous!
https://www.sau.com.au/forums/topic/77777-r32-sunroof-urgent/
oh and id like to express my disliking for the nissan place in vic park....quoted $1800 for JUST the glass of the sunroof. I thought he was cracking a funny one.
* Contacted Prestige sunroofs. They can only offer me fitting services and recommended i try a glass cutter. He seems to think perspex is illegal and will splinter, i will need "safety glass" which is meant to shatter upon impact.
Anyone on here a glass cutter? :hearts:
um no i got quoted $300 for a $5 brake piston seal. :confused:
you mean duncan nissan?
go to the service section and ask for Brad. he knows who you are and may be able to hook you up with a cheaper version of the same thing :uh-huh:
tell him simon sent u
Thats kool, his car doesnt look boonga? maybe i didnt pay enough attention.
So far it has cost me $20. I got some free perspex and the $20 was the cost to get it cut to size. Now I gotta get it fitted with glue and bolts. Dunno how though, any ideas? someone else with a sunroof- how is it fitted?
  • 1 month later...
Curious if anyone can help me with the sunroof seal and a plastic surround for the outside? need it urgently.
Hey Steve, there was a wrecker in malaga that i found who had a whole r32 roof with sunroof still in tact. Once i find out their business name, ill write it up here. (Im getting a roof with sunroof from jap for cheaper- that's why i didnt buy it).
Can you please get me his details asap, or the person who is importing your roofs detals please asap!
Thanks!
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
