this may be a stupid question but i was wondering is this could be done
get a r33 compressor and exhaust housing and machine them out to fit this
http://page13.auctions.yahoo.co.jp/jp/auct...ction/r10821691 (only buy one of them)
would this work? i was just thinking that a new high flow turbo costs about $2000 and if you did it this way it would cost about $1000. it would have brand new bearings and wheels. i know it wouldnt be the same as having a gt2530 but would it be reliable?
just a thought
https://www.sau.com.au/forums/topic/78138-high-flow-turbo/
anyone?
I suppose it also depends on how much it would cost to machine them and also how perfect they make it.
If the cost is too high to machine them and also depending on cost of postage and duty to import bearings, it might not be worth it if you are only saving a small amount?
If you search the net you can find GT series turbos for less than $2000.
I got a GT30R for $1700 but also found a guy in the U.S which said he would send it for US$1050 not including freight.
Check out how much someone like Precision turbo's would machine before deciding anything like this.
Hope that sort of helps.
https://www.sau.com.au/forums/topic/78138-high-flow-turbo/#findComment-1430797
    • Just had this happen to me too.  R32 GTR.   Also broke "just before going out onto the track" - someone up there is looking out for us... Very scary since I was about to do a narrow street course with zero run-off and curbs everywhere. Many people on here upgrading to billet uprights and R35 bearings?   Or buying new OEM knuckles?  I am not keen to replace with another s/h 30 year old fatigued part.
    • Top off with distilled water and see what happens. If you keep losing coolant then you know to start looking.
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
