  • Replies 117
Originally posted by ex-static
12886924 (wow ive got the oldest icq number out of all of your.. gah.. im a nerd :))
hehehe, beatcha... beatcha...
ICQ 1475150
MSN [email protected]
And I use trillian so bleh youse will all pop up on the same window anyways.
https://www.sau.com.au/forums/topic/7820-icq-msn/page/2/#findComment-116997
From ICQ Website
On November 1, 1996 three kids, Arik Vardi, Sefi Vigiser, and Yair Goldfinger, released ICQ to 40 beta testers. The first ICQ number was 100,000. The three founders had a few numbers under 100,000.
Unless your mate was one of the developers or one of their mates, I doubt he'd have a number with 5 digits. :P
https://www.sau.com.au/forums/topic/7820-icq-msn/page/2/#findComment-123819
Originally posted by funkymonkey
Unless your mate was one of the developers or one of their mates, I doubt he'd have a number with 5 digits. :D
lol i'll have a look when i get home... i was damn sure it was 5 tho... obviously not. guess im dislexic.... :P which is most likely
https://www.sau.com.au/forums/topic/7820-icq-msn/page/2/#findComment-124352
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
