  • Replies 117
You think you got the oldest icq number???
Try this out:
ICQ 873042 (hardly used, but I BEAT YOU exstatic!!!) :bahaha:
MSN [email protected]
Feel free to add me...
Rianto
Originally posted by ex-static
yea trillian rocks :)
anyway...
12886924 (wow ive got the oldest icq number out of all of your.. gah.. im a nerd :))
[email protected]
https://www.sau.com.au/forums/topic/7820-icq-msn/page/3/#findComment-131573
In fact I just gava Gerald a call this morning..... and apparently it could finish tomorrow or Thursday... they're waiting for the car back from an auto electrician to bypass the neutral safety starter (otherwise car won't start as it thinks still in gear 'D').
Anyway I can't make it on Wed, so if car is finished, I hope I can drive it home on Thursday. But Gerald still needs to replace my brake pads and suspension bushes.
I dropped the car in last week's Monday evening, so considering the progress it's pretty quick!
https://www.sau.com.au/forums/topic/7820-icq-msn/page/3/#findComment-134072
  • 3 weeks later...
Originally posted by predator666
yep, and in fact Yahoo and IRC. So basically you through one client access all these networks through your normal logins to speak to your friends, etc. Its very nice. Give it a try and see.
does that mean i can access irc from work
cause ive tried to dl it and it wont connect
https://www.sau.com.au/forums/topic/7820-icq-msn/page/3/#findComment-209333
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
