Hey guys, I have access to a decent series 1 R33 RB25-DET gearbox. Just curious as to if there was alot of diffrence between the 3 RB25-DET boxes? I know cubes guide touches on it a bit, and im not talking about clutch differences. Can they all handle the same power?
Also what is invloved in fitting one to a R32? It will be behind (eventually) a RB30-DET
Steve
https://www.sau.com.au/forums/topic/78240-rb25-boxes/
If anyone tells him to do a search, do it yourself first, there isnt a lot of info really, not in the one topic at least.
Maybe the few people who have done the conversion, and actually know what they are talking about post it in here and we make a sticky topic?
https://www.sau.com.au/forums/topic/78240-rb25-boxes/#findComment-1429081
ok....here we go :)
r33 box bolts up to rb20/25/30 motor and gearshift is in same spot.
U need : rb25det gearbox, rb20det tailshaft end that bolts to diff, r32 gtr speedo sender, r33 red cog off speedo sender in r33 box u have, custom tailshaft, custom gearbox mount, r33 gearbox yoke.
R33 gearbox is longer so using a auto x member only works if you have an auto chassis to begin with (bolts in).
Cut the brown r32 gtr cog off the sender, and swap it for the r33 red cod (do a search i showed pics on "speedo sender fixed")
Any other q's lemme know :)
https://www.sau.com.au/forums/topic/78240-rb25-boxes/#findComment-1429169
Earlier r33's like 92-93 use the push, later ones use the pull.
I wouldnt worry about which one is internally stronger. If you are that worried, get an OS gearset, or dogbox.
There is a conversion to make push to pull, or pull to push....i just used the push to keep it the same as the r32 setup.
https://www.sau.com.au/forums/topic/78240-rb25-boxes/#findComment-1429651
Thats the whole reason for the conversion. If I wanna know if i can get away with a series 1 box, as its easier.
Realisticly i need this box to hold 450ish rwhp daily, which ive heard the 25 boxes can handle.
https://www.sau.com.au/forums/topic/78240-rb25-boxes/#findComment-1429688
The reason I was asking about which had which type of clutch so we can make the one thread and sticky it. So we dont have to go thru like 20 others to try and find the info. I think as people use the RB20 more as its a cheaper motor, they will want to be using the rb25 box. So to save the hassles, one thread with all info would be much easier yeah?
https://www.sau.com.au/forums/topic/78240-rb25-boxes/#findComment-1429798
ok....here we go :rofl:
Hi there,
when u say speedo sender u mean the whole speedo cable?
https://www.sau.com.au/forums/topic/78240-rb25-boxes/#findComment-1430140
I would say that all the RB25det boxes are of same strength, Possibly newer ones might hold up a bit better if they arent as fatigued as old boxes...
A cheaper alternative to the GTR speedo sender is the Nissan Navara speedo sender, Ive posted the part number numerous times here. It should only cost you $24 and readily available at your local Nissan Parts dealer. I think the GTR speedo sender is around $150 and has to be brought in from Japan
https://www.sau.com.au/forums/topic/78240-rb25-boxes/#findComment-1430160
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
