  • Replies 95
My old R33 now owned by Mik recoreded a 11.7sec I think It had GTRS's. wr hoon will have his R34 on the strip soon with the GTSS's.
My R34 will get to stretch its legs soon with its GTSS's.
guys,
anyone here know of any gtr's with the gtss &/or gtrs setup that have recorded 1/4 mile times?
im am interested in seeing this information as im sure others are as well...
marko
Yeh Mik's car from memory think his best is 11.3@125mph std internal rb26 with gtrs's .Think he will be out there again soon has some half decent rubber on the thing now and will be looking for a 10 .
Marko only real way to find out is to get out there and have a go I soppose as every car is differen't . Tell me if you do go out would like to spectate .
And all the gear bolted onto another car with a set of cams ran an 11.3
A touch off topic here sorry, do gt-rs flow pretty well the same as 2835's? If so they are pretty damn big low mounts
HKS GT-RS are rated at 400ps each, and have the same compressor wheel diameter as the HKS GT2835 which are only rated at about 380ps each (IIRC).
So yes, they are just as big as GT2835s and are MASSIVE low mounts :D
They need a 2.8L or 3.0L stroker to retain low-rpm tractability and torque...
I guess any 'larger than standard' turbos will perform better with an increased capacity bottom end but in discussing this topic I think that 362awkw with 800Nm is quite an achievement on a stock 2.6ltr - yes it is all up & over 5000rpm thru to 8500rpm so the larger bottom 'would' beef up the low rpm...
Marko.
Marko.
I guess it depends what you want to do with the car.. My setup is more of a street/track setup which is what merli was going for..
Yours is more of a drag setup!!!
I'll overlay the torque curves when i get home should make an interesting comparison....
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
