in the top photo:
either the chick with green shorts/white top, or the chick two or three to her left.
Bottom photo: hard to tell from distance, either the chick on the far left, and if I wasn't late for work the one with pink bottom and black top.
But after a few drinks on a friday I wouldn't be so picky, except for man/women 4 to the left from far right.
in the top photo:
Totaly agree!
Cars there weren't worth all that great, but here are some of the better photos, which about 5 pages of the gallery consists of.
Enjoy.
http://www.tharaka.com/Showoff
second one from the left YeeeeAAAH!
wonder what she's thinking about in the pic above hmmm ?
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
