  • Replies 68
R33 I reckon for looks, can't beat the Skyline tail lights.
Although, 180sx look good as a package, more sleak.
In terms of performance, i think standard, R33 would be slightly better, but a 180sx has better dollar for dollar modification potential.
As everyone has summed up, both are great cars, really comes down to personal preference.
Good to see ppl are giving real opinions instead of "get the line mate" that ud expect.
If i was to ask the same comparison but instead of 33 GTS-T say 32 GTR would it b fair to say that it would b a unanimous decision on the GTR? (myself owning a 180 atm going 2 a GTR)
BTW...to the topic starter, who did u get ur loan with?
What about buying an excell and spending your left over cash on a big subwoofer, getting the engine bay chromed and a couple of GTR badges... and some full sick chrome wheels... and a custom license plate... ...bad joke hey...
180sx/skyline both excellent cars... I think you'd be happy with either. Just get whatever comes up first at the right price.
Also, I am unaware of any significant differences in "service" costs for skyline/180's and any other imports for that matter. I pay the same to get my car serviced as my old man pays for his old 4cyl pulsar.
You think, and you are wrong. :mad: The 180sx in terms of performance, is quicker. And yep, dollar for dollar mods it is also better.
180sx/Silvias are for boys.. Skylines are for real men
Can the thread starter see any appeal in smoking every r33/v8/wrx etc you see at the lights with attitudes like this? It is what I loved about my s13 :D
Buy a FMIC, 3" straight through, boost controller, then show them who the real men are :uh-huh:
See if you can find a sr20det manual silvia instead. It's exactly the same as a 180sx. dewing it, debadge it and drop it.. then you'll have even more people thinking they are in a faster car than you. So much fun.
Yeah, Silvias are great. Too bad they're fugly ;)
Particularly when your used to only seeing the back of them! :Pimp2:
:innocent:
I think that the silvias, 180sx's and r33s all look fugly in stock standard form.. thats why people modify them right?
Well a 180 needs standard skirts and some clear indicators to look good, doesnt cost to much.
A silvia needs alot of work while the Skyline can get away wit a type M kit on it which is fairly cheap... (both r32/33s). R33 series 2s look good in stock form aswell as nearly all R34s.
I thought people modified because of fast n furious?
I know the only reason I get Harry's to order overnight parts from Japan for my piston engine is because Dom uses them on his rotary.
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
