hey guys... got a 32 gtst type M for sale
as the guys in sav-vic wud know i only just recently recieved the car as an import.
compliencing is done as well as rwc. its got about 11mths rego now since being registered, but hasnt been driven anywhere coz its at my frends house (parents still dont know abt the car) :Oops:
anyways heres the specs:
1989 nissan skyline R32 Gts-T type M.
black
141,700 kms (had 140,800 when photo was taken in japan)
5 speed
RB 20DET
HKS 2530 turbo
HKS mushroom pod
Full 3 1/2 " including hiflow cat, exhaust (bar dump pipe) and new mid muffler
ORC heavy duty cluth
Full Tien HA coil overs
16" final speed rims
GT-wing (suits the car, but not used due to legal issues)
Blitz Boost controller
Blitz Turbo timer
oil breather kit
HKS SSQV bov (not installed)
Louis sumthing sports steering wheel (not pictured, but very comfortable n small)
11mth rego n roadie
looking for $13k (open to offers but no swaps please) inc roadie n rego
car hasnt been driven much, been based at the mechanics and only recently been moved to a private residental adress so no dumb shit been happening. the car has got the fruits for drift, its 1/2 set up for it. only needs intercooler ecu fuel pump n injectors id say. i havent tired to drift the thing, i havent got the skills n its scary enough trying to drive normally :newbie:
contact me via pm or call
http://i4.photobucket.com/albums/y109/nghi...iagero/32-5.jpg
http://i4.photobucket.com/albums/y109/nghi...iagero/32-2.jpg
http://i4.photobucket.com/albums/y109/nghi...iagero/32-4.jpg
http://i4.photobucket.com/albums/y109/nghi...iagero/32-6.jpg
http://i4.photobucket.com/albums/y109/nghi...iagero/32-7.jpg
http://i4.photobucket.com/albums/y109/nghi...ro/DSC00013.jpg
http://i4.photobucket.com/albums/y109/nghi...ro/DSC00010.jpg
cheers!
https://www.sau.com.au/forums/topic/78782-fs-r32-gts-t-type-m/
black
5 speed
RB 20DET
HKS 2530 turbo
HKS mushroom pod
Blitz Turbo timer
oil breather kit
11mth rego n roadie
cheers!
saw your car, would you sell for 11.5k and take off a few things off the car?
Im in westall
    • My thought is if you were just moving it forward and the upstream geometry remained the same, then no difference at all. But because the current one has the filter direct into the AFM inlet, you effectively have the best chance of a completely symmetric air flow profile upstream, and in, the AFM, whilst the aftermarket inlet thingo has a (small, to be sure) bend between the filter and the AFM. That would bias the flow to the outside of the bend (downstream of the bend) which might well reduce the size of the signal seen by the AFM, for the same total flow rate. Having said that: If you're proposing to make your inlet look like a hybrid of your existing one and the aftermarket one, such that there is no bend where the filter is clamped on... then I say it will be just fine. If there is going to be such a bend, then, if you can align the insertion of the AFM blade such that it is at right angles to the plane of the bend, then there is a better than even chance that the centreline velocity where the blade is will remain more or less the same, and the velocity will just be a little faster to the outside of that, and just a little slower to the inside. **This is not professional investment advice and you should consult a suitably qualified ouija board, tea leaves or the intestines of a goat for more accurate prognostication.
    • Hi Tao, Thanks for your reply.  It's been a while and I managed to get the valve stem seals replaced with the head on the car.  Unfortunately this didn't solve my issue, the car still smokes a lot after idling (to be honest during idle you can see a bit of blue smoke from the exhaust), same after deceleration. I will try disconnecting the valve cover breathers, do I leave the PCV valve in? By engine oil drain pipe, do you mean the turbo oil drain?
    • What about if you just give it direct 12v and earth?
    • Hi guys . Can someone help me  I bought an Android screen for my Nissan fuga but it won't turn on
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
