Hey, Can u please calculate my spring rates?
Figures as follows..
FRONT
155mm inner diameter
14mm wire diameter
3.8-3.9 coils
REAR
125 outer diameter
10.75 coils
13mm wire diameter
5 Sacraficial coils
Thanks Steve
Front = ~240 lbs/inch (4.3 kg/mm)
Rear = ~130 lbs/inch (2.3 kg/mm) on the soft rate and ~295 lbs/inch (5.3 kg/mm) on the high rate
:) cheers :(
  • Replies 378
Hi Gary,
Can you tell me the rate of these coils (attached in pic)
Fronts are
98mm ID at the large end, 10mm dia coil
67mm ID at the small end, 14mm dia coil
9.25 turns
Rears are
102mm ID at the large end, 11mm dia coil
88mm ID at the small end, 13mm dia coil
10 turns
Hi SK.
These are the coils i'm considering for my R33 GTR.
Fronts
Coil ID = 97/70 mm
Wire OD = 12.7 mm
# of Coils = 8.5 turns
Rears
Coil ID = 103/91 mm
Wire OD = 12.7 mm
# of Coils = 7.5 turns
Bilsteins coils.
Can you give me the rate in KG too please.
Edited by Vspec R33
  • 3 weeks later...
Hi Gary,
Fronts are
9.25 turns
Rears are
10 turns
The front soft rate is around 185 lbs/inch (3.3 kg/mm) (they would never run at that rate, the top 4.5 coils would sit on each other and it would be at the high rate all the time)
The front high rate is 650 lbs/inch (12 kg/mm)
The rear soft rate is around 115 lbs/inch (2.0 kg/mm) (they would never run at that rate, the top 4.5 coils would sit on each other and it would be at the high rate all the time)
The rear high rate is 350 lbs/inch (6.3 kg/mm)
:kiss: cheers :D
Hi SK.
Fronts
Coil ID = 97/70 mm
Wire OD = 12.7 mm
Rears
Coil ID = 103/91 mm
Wire OD = 12.7 mm
Bilsteins coils.
Front = 245 lbs/inch (4.4 kg/mm)
Rear = 195 lbs/inch (3.5 kg/mm)
:kiss: cheers :D
:) cheers :D
Wow,
Well that's a bit higher than I was expecting for the fronts! :thumbsup:
Got them in the car on the weekend with new KYB shocks, and it handles beautifuly. I would expect it to be harsh with this rate but its fantastic.. not sure why but feels really good.
oh well, can't complain lol
Wow,
Well that's a bit higher than I was expecting for the fronts! :)
It is always a bit difficult to rate tapered wire coils, to be perfectly accurate you have to know the amount of taper over the full length of wire. Or test them on a spring rate tester. That's not very easy to DIY. The rates that are calculated are the lowest posssible (assuming maximum taper) and the highest possible (assuming the minimum taper).
:) cheers :D
Hi Gary,
A few 'on the car' measurements I managed to get. I find them a bit too harsh for Sydney streets.
Front:
Coil ID = 64 mm
Wire OD = 11 mm
# of Coils = 7 turns
Coil length = 180mm
Spring rate =
Rear:
Coil ID = 64 mm
Wire OD = 11 mm
# of Coils = 8 turns
Coil length = 200mm
Spring rate =
Rear springs:
Edited by Scandrew
Hey mate
I am not sure if this in your area of expertise but I am looking at grabbing a set of King Springs
The part number is KPS-101-X5K
As you probably know they go up by 25lb from 200lbs to about 1000lbs
Anyway. I want to run these in the front of a datto 1600 on r31 struts. The car will weigh approx 1000-1100kg with me in it.
What is a good spring rate for this car used on the street with KYB uprated shocks giving a firm yet comfortable ride? I think hub height to guard is about 330mm if that helps at all.
I have been told 200lbs is a good rate.
Any help would be most appreciated.
cheers
James
Hi Gary,
Front:
Coil ID = 64 mm
Wire OD = 11 mm
Coil length = 180mm
Spring rate = 375 lbs/inch (6.7 kg/mm)
Rear:
Coil ID = 64 mm
Wire OD = 11 mm
Coil length = 200mm
Spring rate = 315 lbs/inch (5.5 kg/mm)
Rear springs:
Hey mate
cheers
James
Hi James, do you want a comment on Kings springs? If so, they are OK, nothing special. Or a recommended rate? If it's a recommended rate then I need to know a few things;
1. What tyres, normal road tyres, R type tyres or full slicks?
2. What stabiliser bar rates?
3. What do you mean by " KYB uprated shocks", are they 1600 shock "uprated"? Or are you considering them "uprated" because they are for a R31?
4. What alignment settings are you intending to run at 330 mm? ie; have you done anything about the camber change when you lower it, or the bump steer? Because if you haven't then you will need ot make the springs excessively harsh to avoid those problems.
Easy question, not so simple to answer correctly.
:thumbsup: cheers :)
Gary,
Thanks for the calculations!
I've decided to go with your recommended street spring rates and ordered a set of King Spring coils 4kg/3.5kg to replace my current Zeal springs which I believe are 6kg/5kg according to their catalogue.
Going to install them today.
Hoping the ride is much more streetable afterwards.
Cheers,
Andrew
Edited by Scandrew
Hey mate new to SAU :lol: Just wondering do I have to take of my springs? If so, is it hard? Ta
Nope, check out page 1 of this thread, it tells you how to measure on the car.
;) cheers :D
does the spring rate have to suit the car for eg, i have a r33 gtst what is the rate on stock springs? what would i be looking to get if i were to get coilovers? would it be the same spring rate as stock? and does springrate stiffen/soften ur ride,
    • haha don't worry I'm sue you've got more fun ahead buying a 30 year old turbo car....but at least you are in the right place to ask
    • some days eh? The keyless entry and interior light on/off with the key will be controlled by the Body Control Module, but I'm not certain where that is or what it looks like (you might get lucky with a search to get a part#, which could be printed on it). I'd start at the A pillar/ Under dash/kick panel on the driver's side
    • It might be hit and miss, but Nissan Genuine Parts and Pitworks are not the same thing, although both are available from Nissan Dealers with Nissan Part Numbers. Nissan Genuine Parts are the OEM stuff, Pitworks are their attempt to get people back from generic parts makers
    • I did end up getting it sorted, as GTSBoy said, there was a corroded connection and wire that needed to be replaced. I ended up taking out the light assembly, giving everything a good clean and re-soldered the old joints, and it came out good.
    • Wow, thanks for your help guys 🙏. I really appreciate it. Thanks @Rezz, if i fail finding any new or used, full or partial set of original Stage carpets i will come back to you for sure 😉 Explenation is right there, i just missed it 🤦‍♂️. Thanks for pointing out. @soviet_merlin in the meantime, I received a reply from nengun, and i quote: "Thanks for your message and interest in Nengun. KG4900 is for the full set of floor mats, while KG4911 is only the Driver's Floor Mat. FR, RH means Front Right Hand Side. All the Full Set options are now discontinued. However, the Driver's Floor Mat options are still available according to the latest information available to us. We do not know what the differences would be, but if you only want the one mat, we can certainly see what we can find out for you". Interesting. It seems they still have some "new old stock" that Duncan mentioned 🤔. I wonder if they can provide any photos......And i also just realized that amayama have G4900 sets. I'm tempted too.
