It would physically fit, the main journals are the same size, the conrod journals on an RB20 are the same as a CA18 so you'd have to have rods and pistons made to suit the journal and the length. To do something cheaply, why not try an RB25 or 26 crank in the RB20, a set of RB26 rods and have some pistons made or modify some 4AG-ZE pistons? The RB20 head will bolt straight on and apparently they still rev really well. You would want some decent quality valves and springs and solid lifters if you were planning on 9000rpm though, I doubt the hydraulics would take it for too long or if the head would flow enough air with the std valves to make worthwhile power at those sort of revs. It also still looks like an RB20 so if it runs good times it will look pretty impressive.
By putting the 20 crank in an rb30 wouldn't you just end up with near enough to a 2 litre engine anyway?
That is sort of the idea - we want revs with less capacity.
Does anyone know of a definitive list of all interchanging components on RB's?
This may be true, but it would have an advantage of having a longer conrod,short stroke and larger pistons compared to the standard RB20 setup.
Does this sound right??
Turbine
Thanks for the respone pro engines. I'm glad that these cranks will fit the blocks.
I could just stick with our RB30DET, but I'm after the high RPM option, at least untill I get enough feedback that it's a silly option, too costly and stuf like this.
Turbine.
Turbine.
There seems to be a couple of threads on this subject. This is as good a place as any;
1. Why do you want a "high rpm option"?
2. Surely a "high power option" is better?
3. On a $per HP basis the RB30 is waaaaay cheaper than the RB20
4. Then there is the average power, which is what gives the time down the 1/4
5. Regardless of the engine involved, high rpm is expensive to build and expensive to maintain, buying a higher diff ratio is cheaper.
6. Buying off the shelf high rpm parts for an RB20 is even more expensive, if you can actually find any. You would have to get many things hand made, and that's going to be even more expensive.
7. BHP = torque (in ft lbs) X RPM / 5250
So 10% more torque at 10% lower rpm = same BHP
8. The reality is 10% more torque is 40+% cheaper to get than 10% more RPM
Sell off the RB20's and buy an RB30 bottom end and an RB25DE top end, spend the same amount of money and the car will be faster, easier to drive and more reliable.
PS; this is not knocking RB20's , great engines, but the economics say there are better alternatives for your purposes.
Ok the high RPM option was to gain reasonable HP with the smaller capacity engine to run in a weight brake class of racing. Smaller capacity = less total weight to carry.
So after reading your reply Syndey Kid, the idea is slowly running away, but.
If we can get the RB20 crank in our RB30 block with our RB25de cylinder head, that would give us the low capacity with the ability to breath at high rpm!
From what I've read so far it seems as though this can be done with rod and piston mods.
If I run a higher diff ratio (numerically high that is), you need more RPM to get you MPH.
The only thing that is preventing me to go with it is cost. Those special cams are unbelievablly expensive, I can't believe people pay so much for them??
Just a side note: I hear of one particular engine runnig at 10,000rpm, I've even heard that some of these guys running RB30's in VL taxis running up to 13,000RPM so the engines must be cappable of doing it.
Turbine
Turbine
13,000 rpm out of an RB30 :wassup: :wassup: :wassup: :wassup:
In whose dreams :bs!: :bs!: :bs!:
What is the capacity break you are aiming for?
Using an RB20 block----
RB20 standard = 2 litres
RB20 with max (safe) bore = 2.3 litres
RB20 with max (safe) bore and RB26 crank = 2.4 litres
Using RB25 block---
RB25 = 2.5 litres
Using RB26 block---
RB26 = 2.6 litres
RB26 with max (safe) bore = 2.7 litres
Using RB30 block---
RB30 = 3.0 litres
RB30 with max (safe) bore = 3.1 litres
None of those options (2.0, 2.1, 2.2, 2.3, 2.4, 2.5, 2.6, 2.7, 3.0, 3.1) require using an RB20 crank in an RB30 block, that makes no sense at all.
Using RB25 block---
RB25 = 2.5 litres
Using RB26 block---
RB26 = 2.6 litres
Using RB30 block---
RB30 = 3.0 litres
Whooo their sydney kid, it's just what these guys running 8's over the 1/4 tell me they are doing. Sounded a bit hard to believe, but I thought their may have been some truth in it :confused:
As for the weight brake. Smaller the engine smaller the weight. I think it's about 8kilo/cubic inch minimum, so 968 Kilo in total for the car, and driver.
Thats great that you did that capacity reference for me, but I don't see one their that says
RB30=3.0Litres
RB30 with max (safe) bore = 3.1 Litres
RB30 with max (safe) bore with RB20 crank = ___ Litres ??????
is that possible Sydney Kid?
RB30=3.0Litres
= 2,516 cc's
Which is pretty much the same as an RB25, so there is no capacity break that isn't already covered.
I don't understand why the hell you would want to use an RB30 block. It's bore is the same (86mm) as RB25/26 but it is 38 mm taller, that is to accomodate the extra stoke and the longer conrods. You aren't going to use the extra stoke with an RB20 crank and none of the RB conrods would be long enough to bring the piston to the top of the block, or even close enough to mill the block. So you would have ot get special conrods made. You could build a 500 bhp RB30 for how much that would cost.
Simply put, the RB20 crank has the shortest stroke and the RB30 block is the tallest, they just don't go together.
What sydneykid has said makes perfect sense, its like your trying to put two negatives together...a short stroke crank and a long stroke block...last time i watched playschool the square didnt exactly fit the circle...but being a boilermaker i learned a hammer and oxy can change that! It would be interesting to see how that would work if you accomplish it Turbine. (no offence intended)
Thats fine guys, it's just my silly way of trying to learn about these group of nissan engines.
The real trick was to see if I could duplicate what the chevy V8 guys do with their odd size small blocks. Using a long conrod with the short stroke. It's like having a mechanical advantage, a second class lever if you like. I would also keep the piston at top and bottom dead centre longer.
Just one question for SydneyKid, what is the length of the longest RB engies conrod?
I'll work it out one way or another i suppose. Just got to keep digging
Cheers
Cheers
RB30 conrods are 6" centre to centre (152.5 mm)
Before you ask, RB26 conrods are 4.783" (121.5 mm)
That's where 31 mm of the extra 38 mm in the height of an RB30 block is used
The other 7mm is in the 11.3 mm of extra stroke and the 1.3mm balance is the piston deck height difference.
:D
PS, when we are changing the rod stroke ratio of Chevy, we don't bother with a handfull of mm's, as you would get between RB20/25/26 cranks. It simply isn't worth the effort.
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
