I am about to install splits in my front doors. At the moment with the stock speakers they rattle when the volume is turned up, so with the splits they will only rattle even more.
What type of sound deadener should I use? I was looking at some stuff at Jaycar the other day which looked like carpet underlay with a vinyl backing on it, is this the best type to use or would a spray be better?
Also, what should I line the inside of my sub box with (its only a 10")?
thanks :P
https://www.sau.com.au/forums/topic/7930-sound-deadener/
As far as i can tell, that is just the buzz due to the crapness of the default speakers rather than any mounting problem.. I have same problem. They could even not be screwed in correctly.
No doubt any premium audio sound deadener will set you back, when maybe even pourous foam rubber could do the trick for half the price. That is really what it is anyway.
https://www.sau.com.au/forums/topic/7930-sound-deadener/#findComment-115885
There is also some stuff called G-Spot Sound max dead or something.. i just ordered a shitload for my car, hopefully it will arrive tomorrow, fingers crossed..
i got it from
http://www.webaudiodirect.com
much cheaper than dynamat etc.. though i am yet to experience the stuff.. i have used stinger roadkill before, but wasn't completely impressed.. brownbread (you can get that from jaycar or the above website) is something that i also used and was impressed with (it is fairly cheap too!)
https://www.sau.com.au/forums/topic/7930-sound-deadener/#findComment-115922
I don't do friday nights, I'm up at 4am each Saturday working.
Sunday is the only time I can go on cruises and at the moment my car is out of action due to an exhaust leak.
It's been a while since I did physics at uni, can waves travel through an air-tight sub box?
How do you test if the box is really air tight? Stick a canary in it and see and if it has fallen off its perch after X minutes? Maybe stick the whole sub abd box under water and see if you can see any bubbles? :)
Mark
https://www.sau.com.au/forums/topic/7930-sound-deadener/#findComment-118303
I dont think you need to test your box to those extremes :) But what I did was run a big bead of roof and gutter silastic around the inside where the joins are, and it sealed the box up really well... The motto is do your best silastic the rest :lol:
Cheers
Sumo
https://www.sau.com.au/forums/topic/7930-sound-deadener/#findComment-118349
Originally posted by MRK25T
How do you test if the box is really air tight? Stick a canary in it and see and if it has fallen off its perch after X minutes? Maybe stick the whole sub abd box under water and see if you can see any bubbles? :D
Mark
lol
like sumo said...silastic does the trick.
when you screw the sub into the box, try not to undo the screws again, it loosens their "seal". the way i test is when the sub is in, i push gently on the sub's cone (not the dust cap:eek: ) evenly, if its sealed, it wont move much. if it has a leak, it will slowly go in. its kinda hard to explain, but dats what i do!:(
https://www.sau.com.au/forums/topic/7930-sound-deadener/#findComment-118467
  • 3 weeks later...
I'm going to stuff my doors with this cushion stuffing tomorrow (already done boot), but i'm not sure which part of the door to put it in... do i put it:
behind the plastic lining where the window winds down to?
-or-
in between the plastic lining and the interior panel?
thanks
https://www.sau.com.au/forums/topic/7930-sound-deadener/#findComment-135699
lol this might sound stupid, but PinkBATTs and all that other home insulation stuff is EXACTLY the same as hardcore sound deadener (in fact most times manufactured at the same plant) lol
https://www.sau.com.au/forums/topic/7930-sound-deadener/#findComment-152009
  • 1 year later...
I have some sound deadening stuff. Not sure what brand it is. Looks charcoal grey/black and about 3-5 mm thick.
Sticky tar looking on one side. I think it got heated up and applied whilst hot.
Not sure how good it is, cause my rear spoiler still vibrates. That might be because the spoiler pads hadn't been reinstalled after repainting. (looking for some replacements if anyone has any - I've got the higher squarish stock spoiler - M-Spec ?)
A definite problem is when I see it peeling off inside the rear quarters. I reckon its probably from the sun. I just push it back on and it stays for a while, till I check it again in a few months.
https://www.sau.com.au/forums/topic/7930-sound-deadener/#findComment-695000
To be honest, the foam thing is really a waste of time. I did that to my boot and hardly noticed any difference - i guess you could if you really listen out for it. The panels stopped rattling as much, but still rattled. The foam i used was acoustic foam, as in the stuff you find in recording studios cos picked it up real cheap.
Dynamat extreme is worth its weight in gold. Haven't used any other brands so can't really compare. Anyhowz, did that to the doors and the improvement was phenomenal. Gotta try it to really know though. And the doors now make that mercedes sound when they close which is pretty kewl. I wouldn't put any foam in the doors if you plan on keeping ur car for a while - yes they will hold water, yes they will then weigh ur car down, yes bacteria will grow in there after a while, and yes it will stink! Plus foam will absorb sound, but doesn't particularly change the resonant frequency of panels (which is the advantage to the stuff you stick on), so wont do much to stop rattling (although it will help).
https://www.sau.com.au/forums/topic/7930-sound-deadener/#findComment-695785
yep, i used the serenity max to cover to boot and under the rear seats.. used dynamat for the doors
i think from memory i got 2 or 3 of their large packs, and 2 large packs of dynamat (to cover int. and ext. door skins)..
it is a good idea to heat the stuff while applying, i didn't and in some places it is peeling off already :)
you are better off getting the densest (is that even spelt right?) material you can get, and use as much as you can afford too :) the more covered the better!
https://www.sau.com.au/forums/topic/7930-sound-deadener/#findComment-707181
    • The rain is the best time to push to the edge of the grip limit. Water lubrication reduces the consumption of rubber without reducing the fun. I take pleasure in driving around the outside of numpties in Audis, WRXs, BRZs, etc, because they get all worried in the wet. They warm up faster than the engine oil does.
    • When they're dead cold, and in the wet, they're not very fun. RE003 are alright, they do harden very quickly and turn into literally $50 Pace tyres.
    • Yeah, I thought that Reedy's video was quite good because he compared old and new (as in, well used and quite new) AD09s, with what is generally considered to be the fast Yokohama in this category (ie, sporty road/track tyres) and a tyre that people might be able to use to extend the comparo out into the space of more expensive European tyres, being the Cup 2. No-one would ever agree that the Cup 2 is a poor tyre - many would suggest that it is close to the very top of the category. And, for them all to come out so close to each other, and for the cheaper tyre in the test to do so well against the others, in some cases being even faster, shows that (good, non-linglong) tyres are reaching a plateau in terms of how good they can get, and they're all sitting on that same plateau. Anyway, on the AD08R, AD09, RS4 that I've had on the car in recent years, I've never had a problem in the cold and wet. SA gets down to 0-10°C in winter. Not so often, but it was only 4°C when I got in the car this morning. Once the tyres are warm (ie, after about 2km), you can start to lay into them. I've never aquaplaned or suffered serious off-corner understeer or anything like that in the wet, that I would not have expected to happen with a more normal tyre. I had some RE003s, and they were shit in the dry, shit in the wet, shit everywhere. I would rate the RS4 and AD0x as being more trustworthy in the wet, once the rubber is warm. Bridgestone should be ashamed of the RE003.
    • This is why I gave the disclaimer about how I drive in the wet which I feel is pretty important. I have heard people think RS4's are horrible in the rain, but I have this feeling they must be driving (or attempting to drive) anywhere close to the grip limit. I legitimately drive at the speed limit/below speed the limit 100% of the time in the rain. More than happy to just commute along at 50kmh behind a train of cars in 5th gear etc. I do agree with you with regards to the temp and the 'quality' of the tyre Dose. Most UHP tyres aren't even up to temperature on the road anyway, even when going mad initial D canyon carving. It would be interesting to see a not-up-to-temp UHP tyre compared against a mere... normal...HP tyre at these temperatures. I don't think you're (or me in this case) is actually picking up grip with an RS4/AD09 on the road relative to something like a RE003 because the RS4/AD09 is not up to temp and the RE003 is closer to it's optimal operating window.
    • Either the bearing has been installed backwards OR the gearbox input shaft bearing is loosey goosey.   When in doubt, just put in a Samsonas in.
