I am about to install splits in my front doors. At the moment with the stock speakers they rattle when the volume is turned up, so with the splits they will only rattle even more.
What type of sound deadener should I use? I was looking at some stuff at Jaycar the other day which looked like carpet underlay with a vinyl backing on it, is this the best type to use or would a spray be better?
Also, what should I line the inside of my sub box with (its only a 10")?
thanks :P
https://www.sau.com.au/forums/topic/7930-sound-deadener/
As far as i can tell, that is just the buzz due to the crapness of the default speakers rather than any mounting problem.. I have same problem. They could even not be screwed in correctly.
No doubt any premium audio sound deadener will set you back, when maybe even pourous foam rubber could do the trick for half the price. That is really what it is anyway.
https://www.sau.com.au/forums/topic/7930-sound-deadener/#findComment-115885
There is also some stuff called G-Spot Sound max dead or something.. i just ordered a shitload for my car, hopefully it will arrive tomorrow, fingers crossed..
i got it from
http://www.webaudiodirect.com
much cheaper than dynamat etc.. though i am yet to experience the stuff.. i have used stinger roadkill before, but wasn't completely impressed.. brownbread (you can get that from jaycar or the above website) is something that i also used and was impressed with (it is fairly cheap too!)
https://www.sau.com.au/forums/topic/7930-sound-deadener/#findComment-115922
I don't do friday nights, I'm up at 4am each Saturday working.
Sunday is the only time I can go on cruises and at the moment my car is out of action due to an exhaust leak.
It's been a while since I did physics at uni, can waves travel through an air-tight sub box?
How do you test if the box is really air tight? Stick a canary in it and see and if it has fallen off its perch after X minutes? Maybe stick the whole sub abd box under water and see if you can see any bubbles? :)
Mark
https://www.sau.com.au/forums/topic/7930-sound-deadener/#findComment-118303
I dont think you need to test your box to those extremes :) But what I did was run a big bead of roof and gutter silastic around the inside where the joins are, and it sealed the box up really well... The motto is do your best silastic the rest :lol:
Cheers
Sumo
https://www.sau.com.au/forums/topic/7930-sound-deadener/#findComment-118349
Originally posted by MRK25T
How do you test if the box is really air tight? Stick a canary in it and see and if it has fallen off its perch after X minutes? Maybe stick the whole sub abd box under water and see if you can see any bubbles? :D
Mark
lol
like sumo said...silastic does the trick.
when you screw the sub into the box, try not to undo the screws again, it loosens their "seal". the way i test is when the sub is in, i push gently on the sub's cone (not the dust cap:eek: ) evenly, if its sealed, it wont move much. if it has a leak, it will slowly go in. its kinda hard to explain, but dats what i do!:(
https://www.sau.com.au/forums/topic/7930-sound-deadener/#findComment-118467
  • 3 weeks later...
I'm going to stuff my doors with this cushion stuffing tomorrow (already done boot), but i'm not sure which part of the door to put it in... do i put it:
behind the plastic lining where the window winds down to?
-or-
in between the plastic lining and the interior panel?
thanks
https://www.sau.com.au/forums/topic/7930-sound-deadener/#findComment-135699
lol this might sound stupid, but PinkBATTs and all that other home insulation stuff is EXACTLY the same as hardcore sound deadener (in fact most times manufactured at the same plant) lol
https://www.sau.com.au/forums/topic/7930-sound-deadener/#findComment-152009
  • 1 year later...
I have some sound deadening stuff. Not sure what brand it is. Looks charcoal grey/black and about 3-5 mm thick.
Sticky tar looking on one side. I think it got heated up and applied whilst hot.
Not sure how good it is, cause my rear spoiler still vibrates. That might be because the spoiler pads hadn't been reinstalled after repainting. (looking for some replacements if anyone has any - I've got the higher squarish stock spoiler - M-Spec ?)
A definite problem is when I see it peeling off inside the rear quarters. I reckon its probably from the sun. I just push it back on and it stays for a while, till I check it again in a few months.
https://www.sau.com.au/forums/topic/7930-sound-deadener/#findComment-695000
To be honest, the foam thing is really a waste of time. I did that to my boot and hardly noticed any difference - i guess you could if you really listen out for it. The panels stopped rattling as much, but still rattled. The foam i used was acoustic foam, as in the stuff you find in recording studios cos picked it up real cheap.
Dynamat extreme is worth its weight in gold. Haven't used any other brands so can't really compare. Anyhowz, did that to the doors and the improvement was phenomenal. Gotta try it to really know though. And the doors now make that mercedes sound when they close which is pretty kewl. I wouldn't put any foam in the doors if you plan on keeping ur car for a while - yes they will hold water, yes they will then weigh ur car down, yes bacteria will grow in there after a while, and yes it will stink! Plus foam will absorb sound, but doesn't particularly change the resonant frequency of panels (which is the advantage to the stuff you stick on), so wont do much to stop rattling (although it will help).
https://www.sau.com.au/forums/topic/7930-sound-deadener/#findComment-695785
yep, i used the serenity max to cover to boot and under the rear seats.. used dynamat for the doors
i think from memory i got 2 or 3 of their large packs, and 2 large packs of dynamat (to cover int. and ext. door skins)..
it is a good idea to heat the stuff while applying, i didn't and in some places it is peeling off already :)
you are better off getting the densest (is that even spelt right?) material you can get, and use as much as you can afford too :) the more covered the better!
https://www.sau.com.au/forums/topic/7930-sound-deadener/#findComment-707181
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
