to all r32 skyline owners of Queensland
Dr Drift is coming to brisbane in august to tune a few cars and if any other owners want their cars remapped let me know to book them in.
Great oppertunity to have a remap done by someone who knows his stuff.
if you are keen let me know as only one or two more can be done in the time we have on the dyno.
https://www.sau.com.au/forums/topic/79369-dr-drift-is-coming-to-brisbane/
David - Price for your A31? Nearly finished decoding the data for them.... Is it factory A31 Silver Top loom and ECU or has it been converted using R32 stuff??
Colin - Long time ago hey.... I've learnt heaps more since then too...
Gordon - Hope QLD's treating you well.... What car are you driving these days?
Dan - Still working on R34 as per R34 thread, at the moment have the ability to tune the fuel and ignition tables, cortesy of Darkhalf. By leaning out the top end it will efectively increase the boost cut threshold, but not remove it. Still unsure of speed cut's etc... I may look at coming up again a couple of months later, so hopefully it should be done by then...
Michael - Can do the GTR no probs.... looking at $300 + plus dyno time, would prefer to modify the ECU prior to coming up, will help maximise use of dyno on the day(s).
Date to be confirmed is either 19th - 22nd, or 27th - 29th....
Sam.
PS: If anyone has any specific questions about their car and coming along, please feel free to e-mail me and see what we can work out....
Its a 1990 rb20, engine and computer. Or so it says on the ecu anyway. Whats rough pricing??? I know its a cheap mod, but atm I got the gearbox to do, so cheap compaired to putting up with it might be a good option.
Dave - What mods? Fairly simple I'm assuming if you're still running stock maps..... probably just plug the map in and give it a power run, max 1 hour dyno time....
Smoothline - ahh the good 'ol days.... have to catch up when I'm up there...
QLD is great, other than the occasional flood :) I've got an R32 now.. just got the basics at the moment.. Would be pushing it.. but its possible I may have time before end of August to stick the highflow rb25 on there and some GTR injectors.. would be nice to get it tuned with all that.
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
