Armed with a datalog of an hour or so on the weekend I will go over my knock map and then up the timing as needed to aim for a knock of 10 all around the map.
Here's what a 2 minute logging run looks for like a "knock map" view for those interested. Very helpful stuff kudos to datalogit (thanks again Jono)
has anyone experimented with turning on VCT earlier or later in the rpm range? worth experimenting with or is it one of those "dont f**k with" settings?
cheers
where did you get 19deg from? you can see part of my ign map from the screen capture. ill post the entire thing tonight when i am at home. its with 0.85bar boost. full 3" exhaust. fmic. pod filter
define "load" do you mean airflow "load" if so then it runs across load point 16ish at max load as the stock afm calibartion only lets you goto load point 16ish
this is my current tune. i made some more changes tonight and have uploaded. for those who are new with datalogit be careful as the default action when datalogit is first opened and loaded (assuming plugged in OK) and if you accidently hit enter is to write the default maps over the top of your tune so be careful (what a silly design flaw).
rename the map file to .dat and open with datalogit
paulr33_193rwkw_ign_up_8_7_6_jump.txt
I'm about to go do some experimenting on my PowerFC with the help of PaulR33's map cross-referenced with mine. Since I seemed to have little trouble when testing with the +5 setting on light throttle, what I intend to do is compare the 2 maps in the N/L 1 to 10 range. Then wherever I find my timing is less than his, increase it by +5 or up to whatever he has set, whichever is less. In the areas where my timing is the same or more than his I'm leaving it that way.
Does this sound like a good idea? Anything I should be wary of that isn't already covered in the thread?
Hey Paul, you reckon you could add a quick Datalogit guide on your PowerFC manual page. If it's that easy to lose your map maybe a breif "Getting Started" with steps on how to download your current map/compare to stock map.
Just scared me with how easy it is to lose current map - I'd hate to lend to a friend and they lost their current map they spent $700 on getting tuned.
Would be great,
Penfold
Best thing to do is back up the tune manually, especially if you spent so much money/time on it. It only takes about an hour to write down all the settings from fuel and ignition maps from the hand controller. You can use a lot of shorthand in the areas where all the numbers are the same. I did that then typed it all up into a spreadsheet which was even quicker.
quick question,
if i want to speed up the spool time of my turbo, during the boost buildup load points do i advance timing to a certain point (until knocking occurs)??? Also does having it abit on the rich side at these boost buildup load points help spool or is it better be more on the lean side???
its a rb20det
cheers
george
Hey Paul, any chance of fixing up the word wrap on your FAQ? At the moment most of the text is a bit too wide to fit on my screen so I have to constantly scroll across and back again for each line while I read it.
    • I know why it happened and I’m embarrassed to say but I was testing the polarity of one of the led bulb to see which side was positive with a 12v battery and that’s when it decided to fry hoping I didn’t damage anything else
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
