i had this issue early when i was doing the faq long time ago
i since moved all the content to tables to support the browser resizing it dynamically, and it should deal with it. should be ok ?
I tried it in Firefox and IE and it still seems to have hard coded line feeds.
Also can I please have a copy of your latest map? Gonna do some more road tuning this weekend :)
see attached, rename to .xls
note its knocking a little in the mid area as i got too carried away up the timing in one spot. my car is having its alternator rebuilt so its not in state to datalog and tune but the rest is fine. use it only for comparison reasons, dont load the exact figures
paulr33___193rwkw.txt
Thanks mate! I'm not loading the exact map, but I'm seeing where you are putting in your biggest timing advances over stock and my tune, and focusing on those areas. Saves me a heap of time not touching the ones which are around the same.
theres one area where it goes over 80ish
but i need to fix it and will done once i have my alternator done.
right click on the filename link and choose save as.
then save it as a .xls
Paul, do you remember where the knock goes over 80'ish? Just so I can keep an eye on that area too and not increase it too much. When I was road tuning the other day there was one area where I slowly increased my timing up to nearly what you had and the knock was virtually zero all the while. Around N5-N6 and L1-10. There were other areas which had more knock that were tuned by the workshop, so I think there's still plenty of room for me to increase it there.
  • 1 month later...
I've made some more changes to my INJ map in the quest for better economy however I don't think it will be good as I expected, time will tell.
I've uploaded my maps to site (in excel and datalogit format) if anyone wants to have a look at them or copy them or do what ever you wish with them.
http://members.dodo.com.au/paul/tunedata/tunedata.html
Are you sure your base timing is correct? Thats alot of timing. You realise that there is no point advancing the timing past MBT as all you do is increase your HC. My general rule is to pull the timing out until you start to loose power. While this is easy to do on a DYNO at WOT its alot harder under cruise and low load conditions. You really need to watch your HC levels to do low load timing.
As far as i know its correct, ive had the car retuned twice from scratch. I basically took the approach of upping the timing on light load / light cruise until it was knocking and then backed if a few deg until it was a smooth balance.
The results were a much more responsive drive and a lively engine. I wasnt trying to gain more power, but was trying to take out the boggy / empty feeling that was expeirenced after a max power only tune. My ignition timing increases only expanded as far as map points 8x8 and only a few deg increase in the last 2 rows for 10x10 so I haven't advanced the timing across the whole map.
I've reset my ecu to clear away the wierd idle hunt bug i picked up somehow in the last week or so. Completed the idle learn procedure and saved the stock apexi maps (ill upload tomorrow night). I then loaded in my ign and inj maps and changed my other settings and all is happy.
HC = Hydrocarbons. basically its what you get when you dont burn the air/fuel mix properly.
What has been stated above is pretty correct, once you tune past MBT you end up with some pretty nasty NOx (Nitous Oxides) emissions as well. Basically means your car runs around clubbing baby seals to death..
Well i took to the streets of melbourne last night with a wideband sensor up the exhaust for some on road tuning and found my afr's were out by a fair bit thanks to me fiddling around. I've since dialed them back into what I felt was right around 15:1 for light cruise up until around 2400rpm where I'll richen it up every so slightly to keep the egt's down a bit.
An hour of on road wideband tuning certainly made a massive difference as far as the INJ maps are concerned and also checking out realtime adjustments. I also experiemented with 02 feedback on and off and found 02 feedback on was perfect, only once the correct INJ values were dialed in.
I'll post up my INJ and IGN maps soon for those who wish to look, my original gung ho approach of dialing in 1.101 for the first 10x10 was completely wrong and opposite, this meant it was more rich which resulted in 13.5 afr's so I wasting more fuel :(
  • Like 1
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
