Hello guys just after a little help and some feed back i have R32, in need of a new clutch. I can get my hands on either a PBR or Excedy H/D, PBR a little cheaper but not much i have 210rwkw, which clutch is better and what is the normal price on something that would suit me don't want a button clutch. I am getting the Excedy for about $480 and the PBR for $400 just need to know one should buy thanks
https://www.sau.com.au/forums/topic/79474-pbr-clutch-vs-excedy-hd/
Im getting an exedy HD clutch put in tomorrow, ill let u you know how it goes. Part no NSK7056HD. Try ABS, they gave me a pretty good price for the clutch, but i ended up getting one at cost price through a friend of a friend..
My car is pretty stock though, probably 130kW at the wheels, so the power comparison wont be that suitable.
The PBR is very poorly built (well all the dead ones I have seen died prematurely).
My last PBR clutch died after 50,000 km. The friction plate was barely worn, but the pressure plate crapped itself.
I don't know of any1 that has had good experiences with a PBR in a performance car.
Hey if anyones interested i had my exedy HD clutch installed today. It feels and works great, took a little while to get used to but i couldnt be happier. The install cost me $250 including machining of the flywheel.
Looking at the standard clutch compared with the exedy HD, the springs on the friction plate are much smaller and the diaphram finger things are not as strong or well built.
My std clutch was worn down to the rivets on one side.
PS i think there is one for sale in the for sale thread at the moment for $400
cool thanks man but i picked one up for $360 brand new with Excedy H/H, rpm brass button pressure plate and bearings 12month warrenty getting installed saturday $150+$30 for machining of flywheel
They are great prices, where did you get them from? Whats a H/H?
My clutch kit was $375 as I had a father of a friend who knows someone who worked a Exedy once or something. Best price i could get apart from that was about $450.
please tell me how much u got it for
i also have an Excedy HD clutch and i think its pretty good, doesnt make any weird noises and love it cause u cant slip it much
ive ran around today looking for a clutch for my GTR.... some of my friends are using the EXEDY ORGANIC CLUTCH an they say its the best thing that they have come across an it cost around $450 to $550
check out BGT clutchs in dandenong its a crapy little work shop, but i went to EXEDY today an they said that BGT clutchs, should give a good price since the buy in big bulk
    • I hope it's actually possible. This is a write off in insurance world.
    • Yup. 2-way with shallow ramp angles. Still works.
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
