  • Replies 45
As much as i love my Trust setuo, i think the ball bearing Garret based HKS turbos are newer technology...but thats not to say the Trust turbos dont deliver the goods. Im still yet to see a std RB20 with a 2530 with the response/power of the TD06-20G.
...But, there is always the but, the 2530 makes almost the same power, with similar response all whilst using the std manifold etc etc. I doubt that the bolt on TD06-20G turbos would match a 2530, could be wrong and wait with interest to see the results of someone running one, but the fact that my TD06 uses the manifold and external wastegate i think it helps the overall performance.
From memory, R31nismoids GT30 equipped RB25 sees about 16psi at about 4,000rpm with a tuned length exhaust manifold and all support systems.
The RB25 is 25% larger in capacity than the RB20 so in theory it would see 16psi 25% later in the rev range at approximately 5,000rpm.
So I guess, if funds allowed and you wanted to take that route a GT30 might be a decent match for a no holds barred 9,000rpm RB20.
mine is with the 82 rear housing, with a .63 you'd be limiting power output of the turbo to around 500hp instead of 550/600... but IMO too laggy for the RB20.
you'd need to wring the guts out of it all day to get anywhere.
Oh, and my 24psi isnt on much later than around 4300-4400 where it goes to 8000rpm
just curious as to what the difference is bewteen a garret and HKS gt2530 are
ive seen heaps of hks version but only for gtr/silvia engines, and ive seen heaps of garret version only for rb series engine. can u show my a pic of a HKS gt2530 and NOT a garrett 2530. i just dont want to buy the wrong one
THX
what about a disco??? anyone heard of anyone using one on an rb20? i'm looking for an upgrade but i would like decent low end but an alright output.. i know you can't have the best of both worlds with out some gassy help but i was just curious if anyones tried this combo?!?!?!?!?!?!?!!?!? oh and if you don't know what a disco is its a garrett GT28RS.
Chris
Strange, but extremely well thought out.. The collector is the most important part of a turbo manifold, and positioning the wastegate like this enables a pefectly smooth collector design (ie no funny holes at strange angles that interfere with the gas flow path even when the wastegate is closed)
Ive seen several big HP drag cars with this mod - it works well.
Its perfect - The gasses going out the wastegate have a clear, unimpeded shot stright through the turbine housing.
Thats the problem. You dont want the air going straight out the turbine housing. You want the air to go thru the scroll of the housing, spin the turbine then out the exhaust. When there is a a certain amount of pressure in the housing you want the wastegate to open and bleed of airflow/pressure so that the turbine does not continue to accelerate.
Wastegates work on basically back pressure (pressure being theoretically equal against all surfaces) whilst the turbine relies on airflow which is directional...
Thats why my gut feeling is that is not the ideal orientation of the wastegate, but could be wrong...just curious to know why it was done this way?
"Thats the problem. You dont want the air goign straight out the turbine housing."
Well, you actually want part going through the housing and a small part going out the wastegate
"You want the air to go thru the scroll of the houisng, spin the turbine then out the exhaust. When there is a a certain amount of pressure in the housing you want the wastegate to open and bleed of airflow so that the turbine does not continue to accelerate."
Thats right - and to get any semblance of decent boost control, the gasses going through the wastegate need to do it easily. If the wastegate gasses have to turn 90 or 180 degrees to go through the wastegate, then they're going to take the easier path and go through the exhaust housing instead, which will cause overboost.
My above post explains why its been done this way. Im sure when Turbine replies he will back me up.
Sorry not convinced. Pressure isnt directional, and wastegates work to regulate pressure. Air is lazy and will piss out wherever/however it can, just look at what happens when you pop a gasket between the turbo flange and manifold.
I have seen this type of setup before, a few old school rotors/VLs etc, and dont have a problem with a wastegate being welded to the housing (very nice welding by the way), but i would have thought the angle at which it has been welded is not ideal.
Anyway, well will see:)
I guess we can respectfully disagree.
In a properly matached manifold, the gasses are traveling at at local speed of sound. They really dont want to change direction. Pressure may not be directional, but flow certainly is, and thats what we're trying to achieve. Flow..
Its a nice job thats for sure...
One thing - Wastegates work to regulate turbine speed, and boost pressure - not exhaust manifold pressure. The wastegate doesnt care what pressure is in the exhuast manifold - it only knows that it has to bleed off exhaust gasses when a certain amount of boost is present.
PS - I Love your Skyline :)
LOL..yeh no problem:) This is a discussion forum:thumbsup:
I know about Mach numbers, flow etc:) But i thought you would want flow thru the turbine first and foremost not the wastegate.
If there was not pressure in the exhaust manifold then there wouldnt be a pressure differential for the air to bleed off and control the turbine speed. The rest of it i agree with though.:)
Will wait and see i suppose...and thanks:)
"I know about Mach numbers, flow etc But i thought you would want flow thru the turbine first and foremost not the wastegate."
Cant disagree with that one :)
"If there was not pressure in the exhaust manifold then there wouldnt be a pressure differential for the air to bleed off and control the turbine speed."
I should clarify this - theres definitely pressure in the exhaust manifold, I just wanted to say that wastegates regulate intake manifold pressure, not exhaust manifold pressure..
Anyways, i think ive said enough :)
Cheers,
Matt
PS- nice to know people can still discuss things without resorting to a pissing contest :)
Roy, I know you like this mod, but air is not lazy, It's a powerfull mother of a thing wich if controlled properly can be used to develope big horsepower. The air at speed becomes like a solid and will not turn corners in a hurry at high speed.
    • Did you panel beat the dents or have you tried to repair this only using filler?  Is your sanding block soft/flexible and is following the shape of the panel rather then just knocking down the high points?
    • I haven't knocked them down yet. I think I made the repair more complex than it should have been. I had rock chips combined with waviness and dents and I tackled it all in one because it was near each other and just end up wasting a bunch of bog lol. I'll knock down those areas and see how I go. And yep what you are saying at the end is correct. I think I might be sanding the top of a steep hill then my sanding block falls into the dent and gets rid of the guidecoat if that makes sense. Though shouldnt unless I'm covering too big of an area with not a long enough block. I'll try something new and provide some updates. Getting there though! Thanks as always.
    • Yeah makes sense, hard to comment on your situation without seeing what your doing. I was talking generally before, I would not be looking to randomly create low spots with a hammer to then have to fill them.  It's hard without seeing what your doing, it sounds like you are using the guide coat to identify low spots, as you're saying the panel is still wavy. I don't see how you're not ending up with patches of guide coat remaining in a wavy panel? Once the high spots are knocked down to the correct level, surely to have a wavy panel you need low spots. And those low spots would have guide coat still in them?
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
