Just some advise, something learnt by experience.  Buy the 040, build a surge tank a little bigger, and mount the 040 inside the surge tank.  This will help reduce the noise from the pump (and trust me a 044/040 is bloody noisy), you can then put as much sound damping material, as you prefer, all over the surge tank to reduce the noise even more.  Fuel will also act as a coolant for the pump.  With a 044 (external) you are unable to dampen the noise as you run a risk of overheating the pump (so i have been told).
Surge tanks? hrm... So what are people going to use as a lifter? Thier old pump that is dying? Thats not a good idea. You should have 2 new pumps, one can be of far lesser flow of course.
As you dont wanna starve the $$ pump later cause you dont know when your stocker pump its died. Then its more $$$ outta your pocket.
For the basic application an intank is best and works quite well.
Im fairly certain my Ext pump on my surge tank is a 040/044, if not its a 984, and i cant really hear it that loud at all and its open in the boot and all
I will get the Fuel pump when I get the PFC tuned.
As far as injectors go, ive spoken to many a performance shop, and said the RB25s injectors seem to be at there max at about 250-260 rwkw.
With what fuel pressure reg?
You would really be pumpin up the pressure in the fuel rail to make this power with std inj. :uhh:
Sard 550cc injectors, 235rwkw, 80% max duty cycle@full throttle
At 185rwkw, std injectors, std reg, 93% max duty cycle@full throttle. So where are you going to find the extra fuel to acheive 250-260rwkw with std injectors?
Gee ur making me think hard now (new owner has had it for about 3mths).
R33 GTS-t, 198rwkw, 3" full nismo exhaust (pretty quiet compared to most GTS-t's), std turbo, std ecu, fmic, k&n, ex cam gear.
:rant:
Nah buddy, i was refering to fuel pump set-up.
Car: R33
Pump: in boot (Ext); in tank; Under car (Ext); etc ?
100% agreed....
Intank 040 is best for general application, but if doing alot of track days i would consider surge tank. Ppl should also get in the habit of filling up when gauge reads a quater, to ensure fuel starvation will not happen an to keep the pump cool.
You must have a different opinion of what is loud, as i heard your pump and it is on par with mine, and yes yours appeared to be a 044 just like mine :rant:
depends what ECU
but 9 times outta 10 you will never get close to that
I've got a stock R33 S2... my thoughts:
I checked mine on the dyno and it was running lean (13.5:1 AFRS). Turns out the pump was on the way out, and it wasn't getting enough volts. For a few hundred dollars, I don't see why you wouldn't upgrade to a better one to ensure your engine doesn't go bang, especially considering it's a rather common problem to have the fuel pumps let go.
I fitted a Walbro 500HP pump and it's been fine ever since :rant:
maybe :)
but if i cant hear it whilst driving along over the exhaust, then i dont care as a general rule.
I fitted a Walbro 500HP pump and it's been fine ever since :P
:werd:
This is why I had my pump changed. Also fixed my annoying starting issue where it would never crank on first turn of the key to full start. You would have to turn it to 3 and wait a few seconds before trying and then it would crank over. The stock pump is one intank pump and thats it
  • 6 years later...
the injectors and regulator control how much fuel goes into the engine, not the pump
the pump provides the rail with pressure and flow
as long as you have enough pressure and flow it is fine
its only when you start sucking more power out of the engine, thus using more fuel you need a higher flowing pump to keep up
if you dont get a higher flowing pump, when you make more power, the engine uses more fuel and sucks more fuel off the rail
but because you have the original pump it can only flow so much fuel and pressure, thus you don't get enough fuel into the rail and injectors
end result is you start to lean out the AF/R fuel mixture, which in turn causes excessive exhaust gas temps and melts the valves and blows the motor
a fuel pump is not something to be short changed or skimped on to save $100
re: reliability
if a fuel pump fails, the engine stalls and it's fine
if a fuel pump cant keep up flow rate and keeps working - this is critical and kills the motor
this is why its important to buy a genunie fuel pump that is rated correctly for your usage
and an even better insurance policy is to have an AF/R guage with warning
welcome from 2005
The pump provides flow, the regulator provides pressure/restriction
Tomei/nismo/HKS pump is still the way to go. I'm so happy with mine, hasn't missed a beat and is quieter then the common alternatives (walbro, Bosch)
Worth spending the extra money
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
