ok i said id update when i had my crap sorted out so here goes. this doesnt have anything to do with ice performance really but if you read over the last page ish it will make sense why im putting it here
172rwkw
rb25, pfc, fmic, 0.85bar, stock pump, stock dump, 3" front, 3" hiflow cat, 3" exhaust
a/f was tuned good around 12ish and seemed to run really well, hardly any knock
clutch died some time after and began slipping from 3k to redline after pump change
180rwkw
rb25, pfc, fmic, 0.85bar, gtr33 pump, 3" split dump, 3" front, 3" hiflow cat, 3" exhaust and 1300kg heavy duty clutch.
after the clutch was done, power check before changing any settings (as in the 172rwkw tune) a/f was just under 10 before doing anything, so the pump pushed the a/f off the planet. this explains why i could smell octane at idle and normal operating cos it was so rich.
power check showed 150rwkw odd ish. go figure?? powerfc reset got to to 160rwkw ish but nice a/f curve just rich as. a/f lean out and some slight timing changes go to 180rwkw.
perfect a/f 12 and the thing hammers now. its 8rwkw difference but it feels so much more
zest and it hammers, havent ever seen it like this and the thing responds very well.
so all in all the dump change the way the car comes on power and top end but didnt appear to "show" on the dyno as easily as i thought it would have. either way the power is stacks better and comes on much better now, this was the first time i was able to run the new dump and 0.85 because since the dump my clutch has been fried.
  • Replies 84
i have a dyno printout the shows the base map and then the final tune so ill put a before and after so you can see, its basically a 30rwkw shift up across the entire rev range also my power doesnt appear to drop off anymore
what i also noticed i set my rsm to measure power output and on the freeway at 100km/h thew it into 4th gear and gave it some curry. max power measured was 311ps @ 5584 rpm. converted thats 231rwkw so go figure :cheers: geez did it fly in 4th gear on full song woooohoooooo
Paul - It's good to hear the car's running well, especially the new clutch... got used to it yet :rofl: there must be a slight difference in dyno's (who would have guessed?) as the 8 kw difference we got would hardly the significant gains your speaking of... Anyway, thanks for the Q45 diagram, and look forward to playing with the Pro software ... mmmmmm
did you tune it Sam at that dyno-mite shop we went to?
would explain the low readings :P
:rofl:
Spot on...
BTW: REAL TIME EMULATION FOR FACTORY ECU'S IS HERE AND WORKING! Map tracing and real time tuning from laptop to Nissan ecu.... mmmm
oops... sorry to hijack thread :P
Sam.
thought I may ad my details for interest sake...
tuned at ICE last week...
stock turbo
3.5inch zorst, stock dump
SAFC
EBC @ .7bar
FMIC
ARC airbox
Rebuilt bottom end with ARIAS forgies
256º cams
208rwkw
pretty darn flat curve too... the figure is probably a bit high but even if you take off 10rwkw to be conservative it is still making 200rwkw with stock turbo and ecu...
yeah the clutch is all good, just a bit jerky cos im still getting used to it.
ive worded my friend up on the powerfc cable so should have it within a week or so
hopefully it works and it can be used, have a feeling it might just work, soon find out.
h nick thats some nice power, the differences we have are cams, dump pipe and tiny bit more boost. seems u didnt get issues from runing larger cams with a stock turbo and normal boost, i just remember seeing bass junkys before and after with tomei cams and he lost power. did you have a before n after on the cams? id love to see how each of ours feel cos cams would be a nice upgrade for the next step
no sorry don't really have a reliable before and after dyno on the cams... they definately made a difference tho, it really likes to rev in the top end now and i got pretty much the same peak power as before the rebuild, just now its at almost .1bar less boost... after I put the cooler on I'm still recording the same peak boost on my ebc just with almost 40rwkw more peak power...
I think a power fc and split dump pipe would give me a better midrange but there are other areas of the car that need work first... I think if your happy with the power and the way the car drives, don't be too concerned with the dyno figure...
Just as an example I recorded 178rwkw before the rebuild on dyno 'a' and then 166rwkw after the rebuild on dyno 'b' with cams and a front pipe added... then added a FMIC and got 208rwkw on dyno 'c'
btw love that series 2 front end... wish I had of know more about R33's when I bought mine
Nigel has been tuning my car since November.Here are the results.
S15
fmic,exhaust,pfc,ebc .............. ...... 180rwkw
Greddy T518Z,afm,dump,inj,pump....200rwkw
Tomei step 1 cams............................235rwkw
HPI exhaust manifold .......................242rwkw
I am replacing the 80mm exhaust with a 94mm next week.
Car has standard bottom end,done 179,000km and runs 20psi boost everyday.
Nigel was the fifth and last tuner to work on my car,I cant say enough about this guy.
S15
are all these figures from the same ice dyno?
cos thats a pretty good increase of 35kw from the cams :uh-huh:
Same dyno,3 months later.I snapped a rocker and thought it would be a good time to upgrade the cams as well as fit a Tomei rocker stopper kit.
The following upgrade to a HPI exhaust manifold,whilst giving me 7kw at the top end,actually gave me 17kw at 4100rpm.Shows the difference paying $1200 for a Jap one with a bit of research behind it over a no-name one on ebay
good stuff, but recently i've been hearing a few stories of snapped rockers on s15's got me worried..
as for the manifold - good to see not everyone buys chinese copies and thinks that their just as good! :cheers:
I had raised the rev limit to 7800rpm,back down to 7200rpm,and my car had done over 170,000km at the time,thats like 12 years driving in Japan,double power output,only failure,gotta love Nissan.
    • Hi guys . Can someone help me  I bought an Android screen for my Nissan fuga but it won't turn on
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
