I wanna rebuild my blown engine. Like everyone, I want something good but keep it low cost as possible.
I was thinking of getting a T78 33D Turbo (around 350kw).
Besides the forged pistons, what other stuff are a 'Necessity' to handle such power.
Those with knowledge in this department, please give me a list of what I am looking at, and how much each part will cost.
Just trying to get an overall view of what i need and $$$ it will cost. If its gonna go above my desired budget, i might have to settle for a hi-flowed turbo, and nothing too serious in the engine.
Thanks a lot.
Husnu (Hus).
  • Replies 64
I know someone who has the whole T78 33D Kit (External Wastegate, Exhaust Manifold, Dump Pipe + a few other piping with it). It will cost me around 3K mark, which is a bargain.
Putting those costs aside - i wouldnt want to spend more than 5K on the engine. (Am I living in La La Land?)
Do not use a T78 to make 350kw. This turbo is way too laggy and you'll have a horrible power band for only 350kw.
Rough estimate using all new Tomei stuff:
Prices USD$
Pistons 1,400
Rods 1,300
260° Cams w/pullies 850
555cc Injectors 780
1.2mm Headgasket 280
Apexi Power FC 1,200
Then you still have to add labor.
What mods does your car currently have?
are you taking the motor out yourself Hus?
if you do and can simply send it off to get machined then you should be able to get it rebuilt for less than 5K...
pistons ($1200)
rods (GTR Rods? $400)
bearings (??? maybe $200?)
water pump ($120?)
timing belt ($60?)
head gasket ($200)
head studs ($40???)
welsh plugs (???)
machining (depending on what you want/need basic tidy up probably cost $2000)
and of course anything else I have forgotten as I am not a mechanic
and a clutch to hold 350kw
Car currently has HKS FMIC, Rajab Racing Custom Clutch, HKS Hypermax Coilovers, 3" Kakimoto Turbo Back Exhaust, Hi-Flowed Turbo, Arnage LSD Diff.
Ok, put aside 350kw - say the T78 will hit 450-500kw - would i still need the same parts as what i was going for a 350kw - or extra parts?
So for 6K (excluding turbo kit) - i wont be able to do much?
still need cams ecu etc i think plus work and gaskets....i dont think 6k is enough..
ok.., throw away the idea of T78
I want to build an engine to suit 300kw at the wheels.
Put aside the turbo kit (I may go for a T67 25G).
Can i get a descent built engine for 6k? Or should i just buy a 2nd hand engine and drive with a 160kw skyline :)
If you wanna make 300kw go with a TD06 L2 20G or a GT3037. You might be able to make this on stock internals. You'll still need an ecu, injectors, fuel pump, and a boost controller. Cams would be a good idea too. I think the stock headgasket is fairly strong on an rb25.
Remember 6k will get you a half cut... So you could sell off the trans and other bits then use the brakes and sell the intercooler... By the time you buy and sell stuff you will have like 2g's left over to spend on cams, pfc & fuel pump..... Thats what id do with 6 g's...
And of course youll get a few bucks for the blown motor
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
