hey guys,
not sure if there is a thread on this already, and to be honest i couldn't really be bothered running a search on it.
Just installed a Kenwood 350W 2 channel into the 32 to run my 6" rears, and have noticed two things wrong that were never there before:
1. ALL speakers are running as fronts. I've kept the same wiring at the back of the headunit, and they ran properly ( 2F, 2R) before i wired up the amp. RCA's are plugged into two RCA's labelled 'F' at the back of the Pioneer head unit. The other two RCA's at the back are labelled SW, for subby i assume, so i left them alone.
2. That annoying buzzz.....frequency noise that goes with the engine.
The battery cable runs down the passenger side, and the remote and RCA cables are running down the drivers side. I've checked most of the wiring to ensure that none of it is touching metal but i can't get rid of the buzzing noise.
Any help much appreciated. Thanks in advance!
https://www.sau.com.au/forums/topic/80319-r32-amp-install-problems-help/
for the buzzing it could be a few things. the 2 most obvious that come to mind is
1. that by run the rca's down the drivers side thay are picking up the wiring loom. when i did my install the power cable ran down the drivers side and the rca's down the passanger.
2. the ground of the amp is picking up ground noise try grounding the amp in a diffrent location
I have my RCA's running down the passenger side, and power down the driver's side.
as for the rears running as fronts you'll need to adjust one of the SW control options. There's a lot of different settings but basically you'll need to turn SW off. (press function when the headunit is off, it should be in there).
ok guys, thanks for the replies.
I'll run the cables down opposite sides and see if there is a difference.
As for them running as fronts, i've turned off the SW option with them plugged in the (f) RCA's, should i plug them into the SW RCA's instead?
Also, i've heard that you can buy noise filters that plug up to the amp somehow - anyone know or heard of this before? Do they work?
Thanks for all the help guys.
ok you found the SW setting- good. with that setting set to full you will have rear fading.
sounds like a poineer uint to me.
if you didn't understand the above do this:
radio off acc on,hold the F key.that will bring up a menu , hit F unitil you get to the preout menu set it to full with the arrows and then F again. trun the unit on and it should be full range.
as for noise. pull the RCA cable out of the radio and listen (engine running) do you have noise? if not them the amp isn't the problem. grab a twisted pair set of RCA cables (jaycar sell them as do I, and check the cables. from there reground the radio . should get rid of the noise prob.
ok chris, thanks heaps for the help. i don't have time to do it now, so i'll do it tmrw.
One more question, and sorry if i sound like a dumbass, but should the RCA's be plugged into SW or F?
It is a pioneer head unit btw.
thanks heaps mate
I fall else fails you could try installing a sound supressor onto the amps positive line. This should remove all electrical sound interference. You can get 8 guage ones from jaycar & strathfield if you are using anything under 12 guage wire (eg if you have a proper amp wiring kit, prob 8 guage).
Its strange because most high-er market amps usually have sophisticated built in sound supressors & dont have this problem, usually occurs with the no-name 40 dolar rubbish you see at super-cheap though :uh-huh:
- Hayden
    • Oof, I will forevermore have those shredded gears in mind whenever someone talks about showing mechanical sympathy towards their car. Thanks for the photos, fascinating stuff!
    • Curious to see how the SpeedTek stuff holds up
    • The holdups last year were drivetrain related. I had the car out right after getting the bearing issue resolved. Third launch and the car didn't move after releasing the clutch. It had sheared all the engagement teeth off the 1st gear.    Thankfully no other damage was done. I set an aftermarket gear beside an OEM gear and found that the engagement teeth on the OEM gear were much larger and better supported. Looking through my bin of spare transmission gears I found that there are two types of tooth on the OEM first gears - the larger tooth and the smaller tooth. It looks like most aftermarket gearset manufacturers base their design on the smaller tooth. OEM large tooth left - Speedtek, OS Giken, etc or OEM small tooth right Decided to give that larger engagement tooth a try. Pressed the ring off an OEM gear and sent it to a transmission manufacturer here in the States. They did their "faceplating" operation with my synchro ring on the Speedtek gear.   I reassembled it, took it back to the track and promptly destroyed the gear itself.  I'll rebuild this and use it as a spare - thankfully just first gear and the countershaft are damaged beyond repair. Definitely disheartening but my welded on engagement tooth ring held up!  Moved to Speedtek's dog engagement design as the gears appear to be much stronger. So far they have taken much more abuse at the track. Also scored a Stillway lockout from the Netherands for super cheap. It's for some other RB transmission so it took a bit of fabrication to fit but honestly a very easy job. I also had to heavily modify the gates as they were very different.   Then for some reason at the last test and tune a silicon coupler below the throttle blew off and took out the radiator and fan. Thankfully it was in the burnout box and not down track. This car is really beating me up - I still haven't made a pass in it. Ran it through the gears many times on the street but it keeps biting me at the track.  Currently in the process of replacing the radiator and remaking the throttle pipe to remove the coupler and use a cast 90 and a vband. I WILL get this thing down the track...
    • Covers most of the above points really. There's a few exceptions but most just see driving as an irritating but necessary task they must complete if they want to get anywhere on time. Also see it as a good time to show their awesome multi-tasking abilities on their mobile and/or doing their makeup.
    • I don't believe I posted pictures of the second oil pump pickup I added so here they are. Data shows it gets oil pressure up to the relief pressure much earlier in the RPM. Is that important? Not likely... This was just another attempt to fix the bearing issues.   I also heavily opened up the inlet to the pump since it now had to flow oil from two pickups. I believe the diameter increased about 1/8".
