Following the positive feedback from the track day on Monday 11th July 2005, Paul & I have decided to book the track (Queensland Raceway) again for Tuesday 30th August 2005.
We will also change the track format mid day to give drivers some variety.
Cost will be the same at $110.00 each and spectators are still free.
Drivers will be required to have a current AASA, CAMS, or MA licence. Licences can be purchased on the day. ($20 for 1 day or $55 for a year)
Numbers are limited, so let me know ASAP (payment into the below account will secure your spot)
I have set up a CBA account for the track day
Commonwealth Bank
BSB: 064 183
Account: 10117368
You need to put your username on the deposit so I know who has paid.
Regards,
Tim
  • Replies 58
Hi Peter,
You have been added to the list already from your post in the other thread. I will be sending out the formal email on this track day tonight and also pizza night.
You can pay either Tim or myself as we are working together on these days now.
I already have 28 reserved spots for this day, so get in quick to reserve a spot.
If you want to be added to the track day mailing list, PM me your email address.
Paul
Excellent. I'll make sure your on the list.
Anyone who is on the mailing list, the best way to reserve a spot is to send me an email. If your not on the mailing list and want to be, PM me your email address and I'll add you and send you the latest Time Attack Track Day email and an invite to Track Day Pizza night. You don't have to have driven to come to pizza night, its open to anyone interested and wants to come along to check it all out.
Paul
hey Gary,
Yes I have you on the list. But I am overbooked for this day so I have asked everyone to either pay now or let me know the day they will pay so I can finalise the start line up. Looks to be the biggest track day yet.
If we keep growing I hope to go to a full day format soon.
ok,
I will try and get the money into your account next week, not to sure if i can as i am away with work and have a very hectic week next week. I f i cant get it to you i will ask Trent to get it to you. But i am a definite, there will be nothing short of WWIII to keep me away.
Cheers
Gary
  • 3 weeks later...
Here is the current line up for next track day. Looks to be a great mix of performance cars:
6 x Nissan GTS
5 x Nissan GTR
3 x Nissan Silvia S13
1 x Nissan 300ZX
4 x Subaru WRX
2 x Ford XR8
2 x Holden Commodore
1 x Holden CV8 Monaro
1 x Holden Senator
1 x Porsche 911 GT3
2 x Mazda RX-7
1 x Mazda MX-5
2 x Toyota Supra
1 x Toyota GT-4
1 x BMW E30 318i
1 x Honda Prelude
2 x Honda Integra
1 x Satria Gti
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
