Just a small point. When the cars come up for auction in Japan, the odometer reading is registered on the website along with a couple of photos, and the condition level (1 - 4). Make sure you get the screen dump from your importing agent.
  • Replies 51
Given this thread has just resurfaced, I thought I'd update it a bit..
Go look at drive.com.au ie http://www.drive.com.au/Search/SearchResul...A%7c&from=4
I'd say the bulk of the stageas on it are wound back, as many simply don't match the types of km's coming out of japan. Yes, there are cars with this many km's on them, but unless every one is coming to a few particular dealers in Australia, and they are not passing on the premium....
Of the adds that give kms -
Year Km's
2001 34k
2000 54k
1999 71k
1999 49k
1999 37k
1999 36k
1999 59k
1998 56k
1999 28k
1999 44k
1999 36k
1997 57k
1997 42k
1997 75k
1997 62k
1997 60k
1997 39k
1996 77k
1996 62k
1996 59k
There is no correlation between the age of the car and the km's! You can almost tell which dealer each car was at by the km's! Do they really think that anyone is going to believe that they have a 1997 car (almost 10 years old) that has done 39K? When I was looking for my stagea, it was very hard to find a 2001 car (in 2005) that had done less than 40k (genuine) - and boy were they at a price premium!
Ian
yeah again im unsure about the hole winding back of digital speedo's it could be something as simple as ressetting it to zero and driving around in it for awhile. im pretty sure when the ford BA's came out they were all programmed through the radio so that the speedo's could be zero'd after they had been moved from ford to seller and it was something as simple as pushing a botton 15 times. i have no proof of this but as they say "rumour has it"
Edited by loymclure
I'd have to agree here. When I was looking to buy my Stag I found the same thing (but you always do now with imports yards anyway). One gleaming example was at a yard at Coorparoo here in bris. It was a '97 model with about 49,000ks if I remember correctly. The interior was very worn (seats, steering wheel, shifter etc) and not so much from neglect (but it was in pretty bad shape) but from use. And just the wear and tear you could see even with out going over the car too much you could tell it was no where near 49000 clicks. I was lucky when I got mine, got the origional manuals, log books, purchase reciepts etc etc all in the little vinyl Nissan Stagea case so I had a full history plus all reciepts from work carried out here in Australia. It was a priviate sale. The asking price for the car at the car yard was $19990.00 and I got mine for $19000 so I decided to drive over to the car yard and show the salesman. Probably didn't change his price as I looked months later and was still sitting there and then he shut down like most do eventualy.
    • I don't think the shuffle can damage the turbos. It only happens at low shaft speeds and loads. It's just annoying (to some people - others are tickled by the effect) and it quite possibly reduces spool performance a little bit.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
