  HKS GT-SS said:
TURBINE:
Wheel = 53.85mm
Exducer = 42.40 (??? Can someone confirm?)
Trim = 62
A/R = 0.64
COMPRESSOR:
Trim = 56
Inducer = 44.46
Exducer = 59.41
A/R = 0.42
  Garrett 707160-7 said:
TURBINE:
Wheel = 53.85mm
Exduce = 42.40
Trim = 62
A/R = 0.64
COMPRESSOR:
Trim = 55
Inducer = 44.59
Exducer = 60
A/R = 0.42
looking at these figures, does anyone have the same list of specs for the R34 GTR N1 ball bearing turbos. I would like to see how the three stack up?
  • Replies 92
Posted Images
  Quote
yeah! Me too! (my bet is they're all the same)
you mean on intake side? ie .60 vs .42.
That's what i was trying to get at as haveing looked at a set of R34N1s the other day i noticed that it has .42 stamped inside the compresor outlet, but another set of R34N1s i've seen has .60 stamped on the outside of the comp cover. So could there be two configs of R34 N1s? Both I've checked were ball bearing, both had the split in the turbine housing seperating the wastegate flow from the turbine flow. Both also had .64 A/R stamped on the exhaust housing. interesting.
edit: also given that A/R is not a size as such (it's a ratio) how much difference in flow/horsepower potential is there between the .60 version and the .42?
Yes :D
I have heard of this too, but never seen it with my own eyes. Maybe someone can clear this up.
yeah it's a mystery to me. I have definately seen both. the .42 ones are often mistaken for .60 as people don't look inside the housing for the A/R. where as the .60 ones are clearly marked on the cover. I would love to know what the deal is there, and also what the power potential of the two variants is?
edit: also the inducer and exducer measurements in the above 34 N1 spec are the same as (within .2mm) the SS and the -7s yet they quote a .60 A/R.
  • 3 weeks later...
  lwells said:
Bump.  R32 TT:  How's it all going?
G'day there Lucien,
Its all not going too well mate actually.
Got the car back together, had a few issues trying to tune it using MAP sensor only and so it was run well on the rich side to be 'safe'. Had it on the road just a couple of days and went down the Collie racetrack. Did only a handful of laps and boom.. blue smoke out the back and loss of power...
It would appear after a compression test that I have lost cylinder number 2.
Interestingly, since I broke the front stock turbo (which is what started this whole damn thing), and number 2 is directly in-line with it (ie the middle cylinder of the front 3), it will be interesting to get the motor apart and see if ceramic has made its way into the engine at all...
So, looks like I am off the road for quite some time. The bills getting it this far have been high enough. Doing an engine rebuild is just not affordable at the moment...
  • 4 weeks later...
  R32 TT said:
G'day there Lucien,
:P
  • 1 month later...
  steve_gts4 said:
does anyone know what boost level the actuators are set to on the 707160 series turbos?
i just got a pair of 707160-7's and it would be useful to know :P
Hi mate, mine were set at 8 pounds from factory. We reset them to 16. :)
Hi Mate,
Did you ever determine if ceramic dust was the culprit?
  lwells said:
Hi Mate,
Hi there Lucien,
Actually I got the motor out over the break and its just been sitting there. Haven't got the head off yet - but will soon. I am making a "shopping list" at the moment... for the full rebuild...
<_<
  Tommyk said:
you dont need to upgrade the actuators. Simply get a boost controller and bleed air off ?
True, but its better to set the actuators as close as possible to the boost you are intending to run. It will build boost quicker than a boost controller detecting, compensating etc..
    • Order for the 2025 model R35 GT-R were accepted from 3rd March and 26th August the last order rolled off the production line at the Tochigi plant. Concerning the R35 GT-R replacement, current Nissan CEO Ivan Espinosa said "Nothing has been decided about the GT-R at this time, but we are well aware that everyone is waiting. The GT-R will evolve and reappear in the future. Please be patient until that day comes." Nissan has a lot of issues with management and finances so take Espinosa's words with a big grain of salt. From what discussions I've had and read about here in Japan, not a lot of people are confident about Nissan's future, let alone the next GT-R.
    • Thanks. We getting some parts along too so he will be solving the speed issue like next week so i will let you know what he came up with.
    • 21 is explicitly the coils detected as the issue. Is it guaranteed the actual issue? No. Just the ECU thinks it is. When you say rattling, describe it better, get an audio clip as best you can if possible.
    • Yea got me coppers. Bad news is I just put them in and the car still has the light and shakes. I also noticed I hear like rattling coming from the exhaust piping right under me. Does 21 also have a possibility of being O2 sensors?   So, coil packs are good, the harness is good, the MAF is working, and obviously the spark plugs just replaced and working.
    • Make sure you drop the GTT base tune back in, and set your injectors again, this will remove anything playing up with it you may have removed. Possibly lean there as it's normally a fast transient going THROUGH atmospheric pressure, and a turbo motor would then quickly go richer as boost builds. The only worry you MIGHT have is ignition timing, as the DE is higher compression than the DET from memory. But again, you're not in boost, so the DE motor will be a lot more forgiving at atmospheric.   Get Murray, Kinkstahs, and Johnny's input on tuning haltechs, those guys have played with tuning enough in the past to be able to help now you're past the trouble shooting stage of the MAP issue
