Dont talk too soon about no drags. I did do a 200 M drag session with UAS one time down at wakfield. It could be organised! Track, Drag, Drift, I dont care as long as it is done safe and not on the roads.
  • Replies 393
Just rereading my posts sorry I did come across a bit negative, I think the idea sounds great but I think to make all things fair as in the go part that in no way should it just be about track which is all I read in the first post about the new idea
Brett
:werd: to OZ and Buster!!!!
yeah.. don't think show and go should just be about show cars and track cars... there is also drift and drag and they should be allowed to represent!
Its a show day, I would expect all cars of all types to be there.
Paul, I think it's a great idea :D
Brett, I think you got the wrong impression from Paul's original post. He wasn't expelling all drag cars... I know when I say "track", I mostly incorporate all circuit AND drag events into the one word :D
An example being, when little riceronis try to drag me at the traffic lights, I tell them to "Take it to the track junior!" ;)
The original idea of Paul's stemmed from the fact that seeing so many awesome cars in one spot just made him want to hop in and go for a burn!!! I'm sure more than one person wanted to hop in their car and thrash it around somewhere after talking shop all day with other skyline-nutters :)
I have to say though, that I'd hate for the day to be tainted by someone being over-enthusiastic and ripping out onto Oran Park circuit and promptly proceed to remodel their car. Perhaps WSID would be sliiiiiightly safer? They also have a huge carpark, and newbies seem to handle straight line driving slightly better than full circuit driving?
The only prohibitive factor I can see is the cost in hiring either venue for the day. We don't make much money on these Show 'n Shine days, and ALL of it goes to subsidising other events and club merchandise... So we can't afford to lose money on any events!
Just thinking out loud, feel free to flame me :)
Guest DIRTgarage
right!! :D  thats what we want!! all sorts of cars there to represent!!  so why are you only talking about show cars and track cars?!  or when you said go did you mean track and drag?!  then what about drift? :D
The drift boys use the kart track...the regulars can be run on the south circuit...8th mile drags on the straight. Run it on saturday... arrange a DJ and some refrehments for an after party and camping so you dont have to run off late in the arvo.
This is starting to get a little out of hand.... Organisational tasks for putting something like this one will be a complete and utter NIGHTMARE :D
I hope all of you people making the organiser's jobs harder will be on the organising committee, because none of this happens magically :) I know that OzGTR02V is going to volunteer a great deal of his time to help organise next year's SNS!
Perhaps before everyone's imaginations runs a little *too* wild, think about how much harder it will be to organise this proposed EXTRAVAGANZA :D Maybe we should keep these days seperated and run them at different times throughout the year.
Marshalling Oran Park South Circuit for the roundy-roundy boys, the main straight for the drag-queen boys and the go-kart track for the traction-challenged ALL AT ONCE would be nearly IMPOSSIBLE.
Guest DIRTgarage
Merli, I have already put my hand up....anyone else?
SkylineNats.
Excellent!!! You're a star Paul :D
For anyone else who is kind enough to give up roughly 3 months of their time after work leading upto this event next year, please PM me and we'll contact you when organising starts next year!!!
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
