Ramen is glorified noodles with slices of meat, chopped up onions and other assortment of vegetables.
Pretty much the same as what you get in other Asian countries, except Ramen is prepared in a neat, articulate manner.
I don't really like it, it still taste like 2 minute maggi noodles to me.
https://www.sau.com.au/forums/topic/80863-ramen/#findComment-1470376
well the instant noodles/ramen is pretty standard i must say.... but the real stuff is fantastic!
anyways ramen is just the japanese flavouring, unlike other asian flavours and ramen is only soup noodle and not dry noodles....
the nissin cup noodle is probably the most famous instant ramen... try them...
you can find them at your local japanese, chinese, korean store...
https://www.sau.com.au/forums/topic/80863-ramen/#findComment-1471133
ok lang ramen is a word like spaghetti...
as there is meatball, cream, etc flavours in spaghetti
the flavours of ramen is literary endless (as fresh ramen is made in different parts of japan with its distinct flavours and ingredients...)
normally instant ones are like soya sauce, pork, seafood, chicken, curry, etc.
very generic flavours...
if you want to make fresh you probably can but is easier looking for it in your local japanese restaurant. it is propably not too hard if you look into your local bookshops for some japanese recipe books or online. you probably want to taste ones in restaurants first so at least you know what its supposed to taste like and look like....
dopefish: i didnt realise there was a frozen ramen... do you mean udon?
as udon is the thick noodle as opposed to ramen being more like thinner noodle.
all this ramen talk is making me hungry! and i miss the ramen sooo much damn it....
https://www.sau.com.au/forums/topic/80863-ramen/#findComment-1472624
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
