Due to extra interest after the first group buy I can offer another 10 Power fc and commander for only $940 delivered.
These are ready to be shipped as soon as full payment has been made.
Come with 12 month warranty
Close date 10/08/05
Payment due - 17/08/05
To suit:
NISSAN
BNR34 Power FC + Commander
BNR32/BCNR33 Power FC + Commander
ER34 Power FC + Commander
ECR33 Power FC + Commander
S14 93-96 Power FC + Commander
S14 96+ Power FC + Commander
S15 Power FC + Commander
RPS13 91+ Power FC + Commander
RPS13 94+ Power FC + Commander
RPS13 96+ Power FC + Commander
TOYOTA
SW20 91+ Power FC + Commander
SW20 93+ Power FC + Commander
MAZDA
FD3S S1-3 Power FC + Commander
FD3S S4 Power FC + Commander
FD3S S5 Power FC + Commander
MISUBISHI
CT9A 98+ Power FC + Commander
CT9A 99+ Power FC + Commander
CT9A 01+ Power FC + Commander
SUBARU
GC8/GF8 92-96 Power FC + Commander
GC8/GF8 96-98 Power FC + Commander
GC8/GF8 98-00 Power FC + Commander
More types available like D-Jetro or AP units - please PM me for more details.
Buyers
1/ liber8_d - R32 GTR - PAID
2/ elbee111 - R33 GTST - PAID
3/ MORE33BOOST - R33 GTST- PAID
4/ limmyR33 - R33 GTST - PAID
5/ Advan_01 - R33 GTST - PAID
6/ mrsky - R33 GTST - PAID
7/ mmmm gtst - R33 GTST - PAID
8/ MYSTR33 - S14 - PAID
9/ JSL - WRX GC8 97 - PAID
10/ PRIVATE BUYER - PAID
Edited by gR33ddy
https://www.sau.com.au/forums/topic/81366-power-fc-group-buy2-940-delivered/
  • Replies 94
I want to get a power FC soon for my car thats landing in a few months. It is an R32 with an RB25 in it from an R33 although I dont know what year the car was that the rb25 came from. Is this going to be a problem?
Greg
AWDMAT - unfortunately Apexi dont have a version of P-FC to suit your HNR32 GTS4.
elbee111 - Ive added you in.
MORE33BOOST - Ive added you in.
limmyR33 - Ive added you in.
:D
Gday Pual.. would it be the same price for an S14 95 Blacktop, also how long will it take to arrive..?
Cheers
Yep. Same price.
Delivery is from 5-10 days after all 10 payments have cleared.
Tracking info will be sent once the P-FC are in transit.
:D
hey paul i see u got S1 R33 GTST as well and spose u'd have a Power FC by now just wonderin how much power u picked up once u had it tuned? and what other mods u got? or anyone else?
I had mine installed and tuned last November.
At the time I had a Stainless 3" exhaust and HKS pod filter and stock boost.
150.2rwkw with stock ECU
183.3rwkw with Power FC.
I reckon it was tuned a bit too hard as I had a few knock issues afterwards. :uh-huh:
Ive now got a Hybrid front mount and AVCR and had another tune when I got these installed.
208.2rwkw on 9.6psi
226.2rwkw on 13.3psi
:D
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
