Peps, As the title says Im looking for Full comp insurance!
Anyone have any good places to go through?
Cheers
Darren
Hi Deluxe,
Here's some return info for you.... :Pimp2:
Try Shannons Insurance (phone number in phone book), then Just Car Insurance (online quote), and maybe Young & Cool car insurance (do a search for their phone number on Yellow Pages, pretty sure they are NSW based).
The quotation all depends on your age and rating history. All above 3 insurance companies should be close in price...... :uh-huh:
Hope that helps.....
Brendan Wilkeson (silky white pearl Stagea) :evil:
Cheers bro
I rang all of those, Young and Cool were too expensive, and Just Car were cheap premium but well expensive excess, and funny enough Shannons, were sweet no too bad off on Premium and excess was the lowest, So it looks like Shannons will have my insurance. Didn't expect Shannons to come to the party at all, but hey well suprised, Gidy up :uh-huh:
Easy stuff,
Im also with Shannons (monthly payment option.....) :uh-huh:
Had a $100 cheaper quote from Just Cars, but my Fireblade is through Shannons, so paying monthly for both vehicles makes it easier. More cash for mods!!
bwilkeson
Easy stuff,
bwilkeson
Yeh i'm hearing ya, monthly payment is all good!!!
cheers peoples
Darren
Just got a quote through Shannons, $4k+ cos i haven't had much insurance in the past.
Went to Just Cars (owned by the same people) they base their premiums on the total time you've been driving, not the number of years you've had insurance for. It's gonna cost just under $1k as they will put me strait to rating1. The excess' are a little more but if i don't crash i'll be fine! They also accomodate for unlimited modifications, as long as they are legal.
I think they are one of the better ways to go if you haven't had much insurance in the past.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
