Hey all,
im thinking about putting in splits on my R33 S2
and i was just wondering how to take out my pillars so that i can put in my tweeters?
the place that i am looking at putting them in is the pillar where the square bit is
if anyone knows what im talking about?
or am i wrong and there is nothing behind that ??
or it is impossible?
do i have to take my whole dash out in order to take out the pillars?
thanks ppl!!
https://www.sau.com.au/forums/topic/81701-driver-pillar-removal-for-splits/
will do guys!! thanks for the info
but what is that square looking thing on the pillar?
like i said it looks like that there is a tweeter behind it.
i jumped into my friends car and it is the same car as mine and he didnt have
the square speaker cover?
i was like wtf?
  • 3 weeks later...
i was like wtf?
The square on the A pillar is a factory grill with a factory optioned tweeter underneath it. I had this in my old R33 sedan. There is bugger all room behind it to mount most aftermarket tweeters from component sets. But I would suggest trying your tweeters in different postions to get the optimal sound.
I have been into SQ for quite a few years and would have to disagree about mounting tweeters in the kicks. Well if it does not yeild the best result from your speakers. I have an S2 R33, initially I mounted the tweets in the kicks, along with angled pods in the doors ( hiding under the door trim ), but I found the soundstage fairly low, mid steering wheel height, and I also found the steering whell blocked a lot of the highs coming from the drivers side. Legs also can get in the road to block highs.
I played around with mounting points and came up with them in the bottom of the A pillars firing INTO the windscreen. I was suprised at the lack of speaker seperation as well. I am very happy with how it is sounding now - wider, higher and clearer.
To get the A pillar trim off (4 door may differ slightly):
unscrew passenger strap/handle by using a small flat head to pop the screw cap/cover.Unnscrew with philips driver.
pop B pillar trim out where it meets A pillar trim.the A pillar trim goes underneath so you need some room to allow it to come out.
Pull A pillar trim out at top of windscreen, there are about 3 maybe 4 clips going from here down to the bottom of windscreen.Work your way down the trim pulling as close to clip as possible, they will be pretty tight, but I have never broken a clip or the trim.
Once unpoped swing B pillar end towards the middle of the front seats and lift windscreen end up and out. Be careful not to break any wires though.From memory the factory tweeters are mounted onto the trim panel.
From memory the factory tweeter cover is easily removable. I can't remember how as it has been 4 years since I had my one with these mounts. After taking A pillar trim off it should be fairly easy to see how the grill comes off.
wow that is alot of work...
that install on the pillar looks pretty cool!!!
but i opted for the easy install right behind the rear mirrors
thanks for all the info guys!!!!
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
