  • Replies 142
Posted Images
LINEUPS Liz!
Godskitchen rolls into Metro City with a bang this Friday night, October 7th. With such a huge line up you're going to need to plan your time wisely with these line up times to make it through the night.
GK 2005 LINEUP TIMES
9.00-10.00pm Adam Kelly
10.00-11.00pm Kenny L
11.00pm-1.00am NICK WARREN
1.00-2.30am BT
2.30-4.00am GABRIEL & DRESDEN
4.00-6.00am ABOVE & BEYOND
yep i do!
Courtesy of ITM and/or Teknoscape...
All pre sold tixs have sold out for GK 2005,
there will be door sales, they are $80
doors open at 9 pm and we suggest peeps get there early to get em
1.00-2.30am BT
I will take a wild guess and say gabriel & dresden were the standouts?
G&D were VERY MELLOW compared to warren, BT and Above and Beyond.
f**ken awesome show but, metro's was a top location
nice seeing dan the man, sneeza, gradenko, boostzor, b005t, gts_evilution (yes i saw u running around)
and of course the usual rice guys :P
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
    • A wise man once told me, "Anything you enjoyed wasting was not wasted".
