I have just been pricing some rotors and pads to buy. Where is the cheapest place to get them, also the Bendix Premium 1398BP seem to be no longer available at most places?
I can get the pads for $121 and rotors range from $252 to $315 each for the same ones, DBA 4909 SR ans SL.
Can I get them cheaper?
Try the 1250 part numbers, they are more common than 1398.
Do you need the rotors desperately? I am working on a Group Buy for DBA rotors and it is going to take a few weeks as I have to complete the tests on the machined to size rears.
:P cheers :D
Edited by Sydneykid
How much will the savings be ... around about price??
Hmm might just wait then, I take it group buys are by cash, not credit card?
Yeh, that's the $1M question, if I knew how much they were going to be I would have finished the Group Buy and posted it up already. I am hoping for 15%, so that will make them around $800 for a set of 4. There may be a little bit more for machining the rears to size. Group Buys I arrange are via direct transfer, it makes the process much easier and the price cheaper.
:D cheers :)
The DBA 4000 series rotors come with temperature sensitive paint on the rotor edge.  This is the DBA instruction sheet for what the temperature sensitive paint is going to tell you.
There are 3 colours (green, orange & red) and they change colour (white, yellow & white) at different temperatures. So I will be able to tell how hot the rotors have been. This will tell me what pads and what brake fluid to use.
I will post up some pictures of the temperature paint on the rotors after 2 weeks use and work through what it means to my future choices of pads and brake fluid.
:D cheers  :O
Quick update, as you can see from the following picture, the green paint (458 degrees celsius) has started to change colour. And the orange (550 degrees celsius) is slightly more yellow. But the red is still red, not white.
I would say I haven't had many brake applications that have resulted in spot temperatures over 500 degrees. I haven't done any real heavy duty towing since I installed the rotors. So I will do another update once I have done that.
:D Cheers :D
Edited by Sydneykid
1. What are the benifits of slotted over normal discs?
2. Do they go through pads a lot quicker?
3. Is the benifit really there?
Suggestion follow;
1. As the pads heat up they give off gas, this gas forms a layer between the pad and the rotor, lowering the CoF. Also small particles of pad compound form a layer between the pad and the rotor, like little ball bearings. The slots scrap off the partiles and allow the gas to escape. Hence you get superior pad to rotor contact and improved braking peformance.
2 Not really, the slots remove stuff that is no longer attached to the pad, they don't remove pad material itself.
3. No it's a wank :D that's why race cars use slotted rotors. It's the rice factor, nothing at all to do with improved braking performance. :D
:( cheers :D
for anyone wanting 328 mm rotors the gtr ones are str8 fit (with brembo calipers also bolt on) and are huge in comparision to stock 280mm ones :P
gotta love nissan and there same hub designs etc so all the brakes are interchangable on most models :O
can slotted discs be machined? or is that not a option on them......
im assuming they will still require some maintainance, in the course of its life...
Yep, they can still be machined, down to the mimum thickness of course.
:P cheers :O
Two questions:
1. Brad, how much were the GT-R rotors, and did you by chance happen to get a price for the single-piece units (i.e. not using the separate hat and rotor configuration)? And do you need 17" wheels (or bigger) to clear them?
2. SK, if doing the mods bit-by-bit, what would you recommend as a starting point and where would you go from there? Is it worth changing calipers too, or are the standard ones holding up well so far under the loads that you've put on them with towing, etc.?
By the way, gents, both cars looks good. SK's with the R33 GT-R wheels (I might consider these myself eventually) and THAT RB26 in your car Brad - what a dream!!! Even better that it looks pretty much stock apart from the wheels.
I love street-sleepers! :)
Thanks in advance,
Nick T.
Two questions:
Thanks in advance,
Nick T.
Hi Nick, the improvement from using the DBA slotted rotors, some decent pads and bleeding the brakes is quite a lot. I can easily outbrake (activate the ABS) with the standard wheels and good 225/50/16 tyres. Thats' with the suspension upgraded and proper alignment as well, so there is plenty of traction. I haven't tried it with the 17's and the super stickies, the tyres are still a bit new to abuse them.
I was having some problem with brake fade when towing in stop start traffic. But that was the compliance pads and brake fluid, I haven't had any problems since the upgrade. I haven't felt in danger of hitting things like I did a couple of times previously. For $800 or so, it was well worth it. If the pad compound isn't up to it, I have a more aggressive, higher temperature and CoF option that I can try.
I don't realy think I will need to upgrade the brakes anymore than that for my purposes. I simply can't justify the cost for what I use the Stagea for. An example, for a set of R33GTR callipers (not Brembos), a rebuild, slotted rotors, new brake hoses and decent pads I would be looking at $2K. I can easily spend that money on parts for the race car, that I know it needs.
:P cheers :)
PS; the height looked good at 340/330 mm but it was a bit low, scraping on some speed bumps (with the standard exhaust) and occasional bump stop hitting. Particularly in the rear with 200 kgs of load. So I have raised it up 8 mm (one circlip groove) front and rear, I have also backed off the front stabiliser bar a bit.
I will try that for a week or so and see how it goes.
Edited by Sydneykid
Two questions:
I love street-sleepers!  :O
Thanks in advance,
Nick T.
hey nick cheers for the comments :) it looks and goes good.. when it goes, wait till the rebuild is done and ill be testing the strength of every stagea component i can tell u that hehe :)
ok the gtr 328mm rotors with alloy hat are retail $600 each side, i managed to get them through a friend who has an account with coventrys so i paid $480 each side.
note the gtr rear 300mm rotors dba slotted one piece where about $300 each so i think the alloy hats jack the price up alot :)
the 330mm rotors and brembo calipers only JUST clear my 17' rims luckily :(
heres a few pics up close...
Repco sell the DBA4909 slotted rotors for $217 each.
They also sell the Bendix Premium 1398BP front pads for $125 plus shipping from QLD.
Do they actually have stock of the Bendix Premium 1398BP's? I'll take 2 sets if you can get them. I had our local Repco guy search through every branch looking for stock. He only found 1 set, they were in Adelaide on the computer but when they went to get them, they weren't physically there.
:) Cheers :)
PS; The Lucas European pads stop well, no squeel either, but (like all European pads) they make brake dust, lots of brake dust.
Edited by Sydneykid
Have you guys called up these guys:
Brake Distributors of Australia
(07)5569 2207 or 0414 868 555
They sponsor the SAu QLD club and are DBA dealers. I have dealt with them before for my old 33's brakes and found them great on price, but I got a discount for being club member of course :)
:D Cheers :)
Hi SK,
I got my wife to do the legwork and ask for pricing (Im at work, she was getting fuses for my abs/4wd problem), word was that there was a set in Queensland.
Maybe I should snap them up!!! :lol:
They sponsor the SAu QLD club and are DBA dealers. I have dealt with them before for my old 33's brakes and found them great on price, but I got a discount for being club member of course :(
Yep, a few months ago. They don't carry stock of Stagea pads (no surpise there) they just get them on order from Bendix. But Bendix don't make them anymore so they don't have stock themselves.
:) cheers :)
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
