I got new pads no problems a few months back, Marc2 helped me figure out what pads i needed and got them sent to his workshop. i wouldn't think they would stop making them as they were on other common cars too. This was for a series 1 by the way
ok...quick questions as little confused after readin this thread.
1. What calipers do Stagea's come with?? (s1) Are they 4 pots?
2. Upgrade calipers ..... is 33GTST worth it, or spend extra and get 33 GTR calipers?
3. I know u guys have mention DBA a stack, anyone here used RDA discs at all??
front calipers are two spot and 1 spot rears, if i was you id go r33 gts-t calipers on the front with dba rotors to suit (slotted) and just get decent pads for the rears and some braided lines all round if ya like :P
r33 gts-t brakes might need 17" rims? or only 16s im not sure, check before u buy :(
front calipers are two spot and 1 spot rears, if i was you id go r33 gts-t calipers on the front with dba rotors to suit (slotted) and just get decent pads for the rears and some braided lines all round if ya like :(
r33 gts-t brakes might need 17" rims? or only 16s im not sure, check before u buy :)
Thats was l was sorta leaning towards. The 4 pot GTST calipers are like $200 (through a mate) .... and l'm sure a set of slotted disc's wouldn't be that much. Are the lines the same for the stagea as they are for the R33, as there would be braided line kits out there already l'd imagine?
Rims are fine, l've got 18's so clearance won't be a problem!! ;):P
Rims are fine, l've got 18's so clearance won't be a problem!! :(:P
im 99% sure the lines r different as the stagea calipers use a banjo bolt line into the caliper and skyline calipers r a metal str8 screw in line.
So really, the best thing for any stagea owner to make it easy for us
Upgrade the calipers to something a little more common
Same applies for the discs...
thats basically the reason l was thinking of upgrading (well and the extra stopping power), esp as the costs to do so werent that extravegent compared to other mods.
Edited by [ STAGEN ]
Yeah i almost bought a set of R33 GTR Brembo's for $2500, full discs and calliper kit, basically bolts onto the stagea. i didn't end up getting it because i decided to get an Autech next year.
my brakes work for now and i don't go thrashing it or carrying bags of cement, so i can stop it without problems. i've had to use the abs a few times already due to idiot drivers.
I have a question..........if the current brakes have enough stopping power to activate the ABS, why do you think changing to R33GTR Brembos will make the Stagea stop any faster?
:) cheers :D
:) cheers :D
Good question - unless they aren't grabbing fast enough (they should be) and they aren't fading (ie you aren't using them a lot ie out at the track etc) wouldn't you be better spending the money on suspension and tires - both of which will improve braking?
Or have I missed something obvious? :P
Yes... very possible. I just went a week with no ABS and no 4WD... just blow an ABS 30amp fuse in the engine bay!!!
:D
If ppl can make a switch to turn on/off the 4WD then the ABS would be exactly the same, but I dont see why you'd want to take off a safety feature as such.
Brendan
:D cheers :(
That's exactly what i took into account when i was looking at buying them. i wanted bigger brakes for the off chance i wanted to test it on track. i quickly discarded that idea because the stagea is anything but a race car.
Or have I missed something obvious? :)
This is exactly where i did spend my money, i spent about $4k on full suspension and tyre upgrade and now the car handles like a dream. i can stick to almost any corner and with the awd i don't lose control where my previous car (r33 gtst) would have. i think i went the more sensible route.
Great tips, thanks fellas.
When Im ready, I'll be grabbing slotted front rotors, good pads all round, and maybe braided lines to the front rotors. That should up the ante somewhat........
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
