I got new pads no problems a few months back, Marc2 helped me figure out what pads i needed and got them sent to his workshop. i wouldn't think they would stop making them as they were on other common cars too. This was for a series 1 by the way
ok...quick questions as little confused after readin this thread.
1. What calipers do Stagea's come with?? (s1) Are they 4 pots?
2. Upgrade calipers ..... is 33GTST worth it, or spend extra and get 33 GTR calipers?
3. I know u guys have mention DBA a stack, anyone here used RDA discs at all??
front calipers are two spot and 1 spot rears, if i was you id go r33 gts-t calipers on the front with dba rotors to suit (slotted) and just get decent pads for the rears and some braided lines all round if ya like :P
r33 gts-t brakes might need 17" rims? or only 16s im not sure, check before u buy :(
front calipers are two spot and 1 spot rears, if i was you id go r33 gts-t calipers on the front with dba rotors to suit (slotted) and just get decent pads for the rears and some braided lines all round if ya like :(
r33 gts-t brakes might need 17" rims? or only 16s im not sure, check before u buy :)
Thats was l was sorta leaning towards. The 4 pot GTST calipers are like $200 (through a mate) .... and l'm sure a set of slotted disc's wouldn't be that much. Are the lines the same for the stagea as they are for the R33, as there would be braided line kits out there already l'd imagine?
Rims are fine, l've got 18's so clearance won't be a problem!! ;):P
Rims are fine, l've got 18's so clearance won't be a problem!! :(:P
im 99% sure the lines r different as the stagea calipers use a banjo bolt line into the caliper and skyline calipers r a metal str8 screw in line.
So really, the best thing for any stagea owner to make it easy for us
Upgrade the calipers to something a little more common
Same applies for the discs...
thats basically the reason l was thinking of upgrading (well and the extra stopping power), esp as the costs to do so werent that extravegent compared to other mods.
Edited by [ STAGEN ]
Yeah i almost bought a set of R33 GTR Brembo's for $2500, full discs and calliper kit, basically bolts onto the stagea. i didn't end up getting it because i decided to get an Autech next year.
my brakes work for now and i don't go thrashing it or carrying bags of cement, so i can stop it without problems. i've had to use the abs a few times already due to idiot drivers.
I have a question..........if the current brakes have enough stopping power to activate the ABS, why do you think changing to R33GTR Brembos will make the Stagea stop any faster?
:) cheers :D
:) cheers :D
Good question - unless they aren't grabbing fast enough (they should be) and they aren't fading (ie you aren't using them a lot ie out at the track etc) wouldn't you be better spending the money on suspension and tires - both of which will improve braking?
Or have I missed something obvious? :P
Yes... very possible. I just went a week with no ABS and no 4WD... just blow an ABS 30amp fuse in the engine bay!!!
:D
If ppl can make a switch to turn on/off the 4WD then the ABS would be exactly the same, but I dont see why you'd want to take off a safety feature as such.
Brendan
:D cheers :(
That's exactly what i took into account when i was looking at buying them. i wanted bigger brakes for the off chance i wanted to test it on track. i quickly discarded that idea because the stagea is anything but a race car.
Or have I missed something obvious? :)
This is exactly where i did spend my money, i spent about $4k on full suspension and tyre upgrade and now the car handles like a dream. i can stick to almost any corner and with the awd i don't lose control where my previous car (r33 gtst) would have. i think i went the more sensible route.
Great tips, thanks fellas.
When Im ready, I'll be grabbing slotted front rotors, good pads all round, and maybe braided lines to the front rotors. That should up the ante somewhat........
    • As I've said elsewhere, I am using the stock intercooler piping path in the engine bay, and a return flow cooler, and making ~250 rwkW (without any effort put into trying to turn it up past there just yet) and expect to be able to make some more, and frankly, I would be perfectly happy with 260-270rwKW. This is peak road Skyline usability territory. You go past there and, sure, the car will snap necks more when it's on boost, but it will also break shit all the time, cost a (even larger) fortune in tyres, etc etc. Anyway, I also do not like the over-the-fan pipe path, and you don't have to do it.
    • I see, honestly I’m not too fussed about the looks. The only reason to go plenum is to make the piping easier instead of the classic over the rad etc.
    • Not easy to quantify wrt something like how many fractions of a second slower it would be over 0-100. But given that a 250-300rwkW car is able to do that launch sprint in 5-6 sec (and faster with appropriate tyres, and surface)..... giving up as much as a second would feel like torture. A ~450HP capable turbo is not going to make lots of boost in the 2000-3000 rpm range. So, whilst with some boost on hand it will be faster accelerating in that rev range than your engine currently is NA, it will not feel like a fast car until the boost is solidly in. You know what your car feels like right now when you open it up at 2000rpm. if you've ever been in an actual fast car, you will appreciate that the NARB25 is.... not exciting. Well, add some boost and it will be better. But shorten the intake runners and it might not be better at all. It might come out better, but it could end up feeling the same. For me, it's not the 0-X km/h sprints that matter. It is easy to fry the tyres with anything over 200 rwkW. You can't use all the power available in 1st and 2nd anyway, you have to modulate the throttle. What matters is how the car reacts when you're driving in traffic in 4th or 5th and have maybe 2000 rpm on board, and you want/need to add some speed quickly, and don't have time for the downshift. It won't make boost, it will be all NA (at the speeds we're talking about - remember how fast you're going at 2000 in 4th! and don't plan on breaking the limit by too much.) So giving away NA torque is not what I would consider practical for a street car. And retaining that NA torque builds boost faster which makes the car faster. The flashy plenum is not actually better, unless you're looking at a track car where you can keep it on the boil all the time.
    • So how much difference does it make you think? Like 1 second in the 0-100?  I was have smaller turbo so hopefully that spools quick GTX2871.  currently it’s NA so you can imagine pretty slow, but I do want fast accusation a little as there’s not many places I’ll be driving where I go over 80 even near me. So 0-60 and 0-80 targets
    • Short inlet runners cost quite a bit. Dulls off the off-boost torque, and delays boost onset, because arrival of boost is driven by gas flow is a product of the ability to flow air which is torque. This is the reason that the stock manifolds have longer runners. On a 3L, or bigger, you can usually accept the compromise of giving away some torque because the extra capacity gives you a little extra to waste. But on a smaller motor, there's not a lot there to start with. Example, I swapped RB20 out of my R32, 25NeoDET in its place. The "wall of torque" that I experienced afterwards made it all worthwhile. That's because I came from RB20 land where torque is not a thing. But I would not do anything, anything at all, to reduce the low/mid torque I have now, because I remember what it is like to not have it!
