does anyone have any s2 c34 brakes that they dont want?
doesn't matter if they are a bit warped, and the thicker the better
also the cheaper or freeer the better
chiuck me a pm if you can help
qld preffered
I have now bought my replacement calipers from off a r33gtst, sumitomo 4 pots ( front ) ans sumitomo 2 pots (rear).
I shall get the gtst discs front and back next.
I have a question, will these calipers and discs fit with the standard 16" wheels? Series1 stagea.
I hope so!!!!
R33's come with 16's standard so you know the diameter will be ok. To quickly check the offset/disc clearance just make sure you have atleast 20-25mm of extra space between the rim and the stock 2pot caliper, the 4pots stick out around that much further than the 2pots.
Edited by QWK32
Hey guys Im looking at a complete brake overhaul for my S1,
just wondering on recommended people to go see in Adelaide southernish area
anyone had dealings with All Clutch and Brake Services? from what im told i need my calipers need to be overhauled, new pads and new rotors, my stag is reasonably stock (soon to add boost controller and safcII) so just wondering what you would recommend as I dont think i will need to upgrade too much even though there will be more power
cheers
Can't suggest a shop but can recommend you get some better quality pads and replace fluid with Motul RBF600. If you are not a driver who stands on their brakes all the time and not intending track days then that and new stock rotors should be fine.
i've done a lot of reading and for a sports pad or to increase the capability of your brakes i'd be looking at some qfm pads
think they are still developing the s1 pad so maybe you could look at getting someones s2 brakes and get those put on, this will get you up to a 290mm rotor which is closer to acceptable for a car of the stageas weight
how much were you looking to spend on recoing the stock brakes?
I assume that last bit is directed at me too be honest I have no idea hence why i came to the bible of stagea knowledge... what ever it costs to a decent but not over compensating as i will probably be getting rid of the car this year and it will never see a race track
why change it then? rebuild kit will be hard to get and exxy. callipers leaking? get some cheap s1 replacements from someone who has upgraded
anyone in adelaide know where i can get slotted disc's for my s2 stag? also what pads do you guys reccomend for high performance street use.....i.e. occasion track day? any estimates on prices?
qfm ar1m pads, now for s2 stags, ebay $179 = win
less dust than bendix ultimates and waaaaaaaaaaay better performance, that with slotted rotors will be a good upgrade
pm "rs73" he could get me new slotted rotors very cheap
*n00b statement* mechanic told me the calipers needed a full overhaul and it would take a couple days plus apparently the rotors are warped.... brakes pulse a bit shudder when hot under hard braking.
the next step was going to see if i could get some second hand ones but i dont really know what im looking for... im guessing if i get second hand calipers its probably still a good idea to get new discs and pads?
if rotors are warped then you may be able to skim them (lathe them flat) but if they are worn and already getting pretty thin then this is not a good idea
second hand calipers can be had cheap, just look at the pistons and dust seals and make sure they havn't been leaking
Thanks mate, just one favor to ask, if you're going to purchase please don't go through ebay. Contact us direct on either 1300 884 836 or email sales at gslrallysport dot com
We'll still honor the free shipping as per on ebay.
Regards,
Greg
Regards,
Greg
no worries, still holding off on mine as im not sure if im gonna get r34 brakes yet
how come not through ebay? do sau members get a discount?
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
    • Well the articals keep saying a Q50s (Skyline in Japan) with a new Manual gearbox. I like the talk about the new looks with the round tail lights. I hope they bring back the retro look like they did with the Z
