Hi Troops,
Im finally going to complete my brake upgrade and plan on doing the rear brakes.
Just need to Confirm;
- That all R32 GTS-T,R33 GTS-T,R34 GTT Rear Calipers + Rotors are 100% the same? As I tracked some cheap R32 rears down.
- Will I need to change the Master Cylinder, to accommodate the extra capacity of more pistons? Ive read a few people have, a few people havn't. Im considering not changing it if theres no real need to.
Thanks, Aerron
I looked into this. On my S2 I have a BM50 master cylinder, so will you probably. That's the same as R32 GTR non Brembo cars and is actually a bigger bore than R33GTST, so should be ok to stay with it
Hi Troops,
Thanks, Aerron
Thanks for that man. I also have a S2, so fingured crossed I have the same.
Now to get my hands on some brakes :D.
I can't remember where I got this info and it may have been posted on here, but might be useful to people.
Front discs
Model Diameter Thickness Center hole height
S15 SR20DET 280mm 30mm 68mm 54mm
R32 M-Spec 280mm 30mm 68mm 54mm
300zx Turbo 280mm 30mm 68mm 54mm
R33 GTST 296mm 30mm 68mm 53.75mm
R34 GTT 310mm 30mm 68mm 53.75
R32 GTR - non V-Spec 296mm 32mm 68mm 54mm
R33-R34 GTR - Brembo 324mm 30mm 68mm 53.75mm
Rear discs
S15 SR20DE/DET 258mm 9mm 68mm 47mm
Skyline R32-R34 297mm 18mm 68mm 63mm
Front calipers
Model Weight Material Thread Pad Piston area
S15 SR20DET 4.8kg Cast Iron 12mm DB1170 40.4mm x 4
R32 M-Spec 3.3kg Alloy 12mm DB1170 40.4mm x 4
300zx Turbo* 3.3kg Alloy 12mm DB1170 40.4mm x 4
R33 GTST 3.3kg Alloy 12mm DB1170 40.4mm x 4
R34 GTT 3.3kg Alloy 14mm DB1170 40.4mm x 4
R32 GTR ? Cast Iron 12mm DB1170 40.4mm x 4
R32/33 Brembo ? Alloy 12mm DB1520 44+38mm x 2
R34 Brembo ? Alloy 14mm DB1520 44+38mm x 2
Master cylinder
Model Type Master Cylibnder Diameter
S15 Spec R BM50 25.4mm
300zx turbo BM50/57 25.4 and 26.9mm used
R32 GT-T M-spec BM50 25.4mm
R33 GTST BM44 23.8mm
R32 GTR non Brembo BM50 25.4mm
R34 GTT ? ?
R32/33/34 Brembo* BM57 26.9mm
S2 Stag BM50 master cyl
R32 GTST
Master Cylinder diam (mm) - 25.4 area 506.71mm^2Front Caliper Piston(diam x qty) - 40.4 ×4 = 5127.58mm^2
Front rotors (diam x thk) - 280×30
Rear Caliper Piston(diam x qty) - 38.18×2 = 2289.78mm^2 ratio FR = 2.239
Rear Rotors (diam x thk) - 297×18
total 7417.36 brake to master ratio 14.63
R33 GTST
Master Cylinder diam (mm) - 23.8 444.88mm^2Front Caliper Piston(diam x qty) - 40.4 ×4 = 5127.58mm^2
Front rotors (diam x thk) - 296×30
Total area 7417.36mm^2 brake to master ratio 16.67
R32 GTR (Non V-Spec,)
Front rotors (diam x thk) - 296×32
R32 GTR V-Spec / R33 / 34 GTR with Brembos
Master Cylinder diam (mm) - 26.9 568.32mm^2Front Caliper Piston(diam x qty) - (44+3Cool×2 ... leading pistons smaller then trailing 5309.29mm^2
Front rotors (diam x thk) - 324×30
Rear Caliper Piston(diam x qty) - 40×2 2513.27mm^2 ratio FR = 2.1125
Rear Rotors (diam x thk) - 300×22
total 7822.56 brake to master ratio 13.76
This is the ratio of master piston movement to overall brake pad movement
R32/GTR calliper ratio 15.43
R33/GTR calliper ratio 17.58
So there isn’t much difference between the Brembos and the std Nissan R32/33 GTST calipers and R32 GTR callipers
for series-1 stagea, leave the rear brake calipers alone
just add metal brake lines, Im using bendix 1144 pads, cheap at $50 axle delivered
for the front, Ive got metal brake lines, slotted rotors, new QFM A1RM 780degree track brake pads, $119 axle delivered
and installed yesterday 4-pot R32 GTR sutimoto front brake calipers
brakes are simply amazing now, stops on a dime
well i've decided that stock s2 brakes are no match for the tassie roads
had a good blast on scottsdale road and as i was coming down the other side i was loosing a lot of feel, heaps of fade and a real soft pedal (think i boiled the fluid too)
will either have to source some 33 rotors or a set of 34 calipers (which are really hard to find in tas :action-smiley-069:)
That definitely sounds like a fluid inadequacy though. Doesn't mean the pads/rotors/calipers aren't up to the task, because at the moment the weak link is definitely the fluid...
Quite possible the fluid has never ben changed. Get some Motul RBF600.
i've bled the fluid on one wide when i tried to put on what i thought were r34 callipers and it was clean coming out, may not be top stuff but its clean and pretty new
road in question is this one: The Sideling
a guy from the thermofluids lab at uni said that he would skim my pads for me if i take them off :D
looks like a good option for now, until i can source some 34 callipers
i think i may make up a bracket as i may be able to get one fabbed up pretty cheap
does anyone have a cad file for r33 callipers to gtr 324mm rotors?
think someone around here mentioned that they had one
cheers if you do, may be able to work out a cheap alternative to brembos :yes:
It might just be standard fluid in that case, which is pretty ordinary performance wise, but it's definitely a fluid inadequacy on some level. Even 'Super Dot 4' (or 5.1 as it's better known) is pretty ordinary and is really only designed for heavy duty application like towing, it's not really performance orientated...
The stuff that we use and recommend is the TRW GP600 Dot 4 Racing Brake Fluid, and is $65 for a 1L bottle. Good for 312 degrees dry, or exactly the same as Motul RBF600.
i'll give them a few bleed, a guy in the workshops at uni said he would machine my stock rotors for me for free :D
so that should hold the fort for now, looks like i'm gonna get some brackets made and run gtr 324mm rotors with the r33 callipers i have
Hi guys,
Not sure if this will help anyone but I got my front brakes on my NM35 changed today as the rotor had warped and was making the most irratating clicking and groaning sound with light brake pressure.
Got RDA954S slotted rotors and Bendix GCT Stealth pads and I have to say they feel so much better. Really firm bite and reassuring pedal feel. No shaking or wobble under firm braking at all.
If any one wants more info let me know.
aren't the RDA954S (machined down a little) the direct replacement for the C34 S2 front rotors???
I didn`t have to do mine,
& just on another note ,i have PM`D the GROUP BUY on brke line`s about sorting out replacement line`s for Stagea,
& as there a long setup he will get back & tell me what he has found,front line`s are 830mm long with block contector`s.
so hope to here from him soon,
cheer`s Chuckie.
PS i have set of 32 caliper`s retapped to 14 mm for sale if any one is looking ,as iam happy with stock pad size against clamping pressure,
not sure what to do guys
i've got r33 callipers, and r34 rotors :( (due to mistake by seller)
now i can either keep the rotors and sell the 33 callipers then buy 34 callipers (but 34 4 pots are really hard to find, $400+ from importmonster + $200+ of shipping)
or someone near me will sell me some gtr brembo rotors (324mm) for $250 and i could then make up a bracket to suit (have access to cad software and maybe to a computerised laser cutter :)) then sell the 34 rotors
or sell the 34 rotors and get some 33 rotors and some 12mm id pipe with a 1mm wall thickness
its for a series 2 rs4s - any help appreciated
thanks, Tom
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
