off the top of my head maybe $5000 buying parts retail??
Upgraded turbo ~$1500
Upgraded ECU maybe powerFC ~$1500
Bigger injectors & fuel pump ~$1000
extras like a boost controller and other little items + labour ~$1000
oh plus a tune
whats everyone else rekon?
I have a 1995 R33 RB25 and just recently reached 198.5kw on the dyno.
Car is running:
FMIC $1000
Full Exhaust System $1200
Apexi Pod Filter - Bought from Nengun for $50
Power FC - Bought from Nengun for $950 w/ hand controller
Exhaust Cam Gear - Bought from Nengun for $180
Splitfire Coils - Bought from Nengun for $450 (Don't think it makes much of a difference)
Turbotech Boost Controller - $30 (Bought from the SAU forums)
13 psi
So all up almost $4000 excl. a couple of tunes I've had and labour.
I got 200rwkw out of my rb20 spending a lot less than that.
Exhaust 3" turbo back $700
r33 turbo hiflowed $800
hybrid intercooler $200
Intercooler piping custom $220
ecu retune an ddyno time $300
boost controller turbotech $30
fuel pressure regulator $170
fuel pump $145
total $2565.
Everything was new except for the turbo. it was a secondhand hiflow. but I have seen decent new turbos for $1200 anyway so for less then $3000 you can have 200rwkw.
the big difference in the equation is the turbo... some seem to make the 200rwkw mark on the stock turbo... mine made 195rwkw but was running way to lean so it was bumped down to 187rwkw at a safe level on 12psi....
you will need:
FMIC
Exhaust
Bleed Valve
SAFC or full Computer
every car is different... my car obviously needs a bigger turbo which i am having installed at the moment, but then you also need:
Fuel Pump
Injectors
AFM
Depends on who you know and what you can do yourself. Shop arround get second had exhaust SAFC ect to cut costs.
-Intercooler kits are gettig cheeper and cheeper around $600 for a Hybrid copy
-exhaust second hand jap brand 600-700 highflow cat and dump pipe $300 or so for both (look in the forsale section on these forums)
-SAFC 350-400 or power FC 950 with hand controller from Nengun.
-$30 boost controller off forums (search $22 boost controller)
at least$250-$300 for a dyno
regap plugs to 0.8 free if you do it yourself.
So it is possible to do it from stock for under $2500 if you can install all the parts yourself but pay for a dyno tune.
My mods and power are in Sig thats pretty close to 200rwkw.
Every can is different though but with these mods expect 180 - 200 rwkw depending on engine condition tune ect. The only thing I would have done different is I should have brought a Power FC instead of a SAFC.
:rofl:
It varies from car to car as others have already mentioned. My GTS-t had:
FMIC
Full 3" Turbo-back exhaust
Bleed Valve (9psi)
K&N Panel Filter
Bosch 040 fuel pump
Greddy Exhaust Cam Gear
Splitfire Ignition Coils
So that all up would be about ~$4k
Notice though that not many (if any) mentioned Splitfire Coils or Exhaust Cam Gear but instead mentioned a tuned PowerFC or an aftermarket turbo... Just shows their are different ways of obtaining power, some people take the easy option (better flowing turbo) and others choose to extract the maximum power out of each part before replacing it.
i have
stock turbo
pfc - 1000
nismo fuel pump - 500
sard fpr - 300
intercooler - 1300 (ripped off i know)
exhaust - 700
AVC-R - 350
cam gears - 250
tune - 550
220 rwkw !!!!!
too easy, now to get a timeslip
either your turbo is a hiflow and u dont know it, or else the dyno was ready very high, as 220rwkw is not possible with your mods, specifically the stock turbo. maybe try another dyno.
btw. what psi were u running?
Turbo back is front pipes, dump pipes, cat, rear exhaust
cat back is just the rear exhaust.
the front/dump/cat will give you another 10-15rwkw along with much better response.
i have
stock turbo
pfc - 1000
sard fpr - 300
exhaust - 700
AVC-R - 350
cam gears - 250
tune - 550
220 rwkw !!!!!
:chairshot
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
