I've seen a car with a maxed out AFM and they get a tune and the air flow meter was working oerfectly with more boost and more power before ... how does this work? Is it tune dependant somehow? How can some people make 360+rwkw on a Z32 yet other say their only rated for just over 250 rwkw?
https://www.sau.com.au/forums/topic/82284-z32-afm/page/2/#findComment-1533046
Mercury Motrsport still run AFM on their S15 with a GT35R, and theirs isn't maxing out ... it just seems strange that a near stock Ser II R33 will max out on 10 psi boost with a stock turbo and stock AFM .... Z32 aren't that much better. I know their better but not by that much.
Edited by ookami
https://www.sau.com.au/forums/topic/82284-z32-afm/page/2/#findComment-1535266
I was going to start a thread, but this seems close enough =)
AFM1 on my 32GTR looses half its voltage compared to AFM2, then clicks back to normal. I reckon if I’m going to replace one, I should upgrade both.
I have a couple channels of thought here,
1] Does the Z32 flow a worth while more then the stock ones? I can get replacements for 180 each, and Z32’s for 300 each; can anyone with experience tell me when ( ie, mods boost, RWKW) does a RB26 run them out of useful resolution?
2] The above is second hand, and don’t you HATE spending money on sh1te that breaks. So I have been looking at new prices *gulp* for Z32’s from Nissan and the Nismo branded AFM’s
greenline.jp quote
“One air flow meter. Twin NISMO AFM setup: 2400kg/h (Approx. 775ps). Twin standard AFM setup: 1400kg/h (450ps). Requires ECU retune.”
Nismo say 775ps ( (775/1.34=578kw) x .70=405rwkw), SydneyKid (511rwkw) and then R31Nismoid 369rwkw on a SINGLE.
I assume The 369rwkw could have been from PFC AFM reference voltage and fuel map tweaking, with SK’s 511 seems more likely, but my question is, when do people hit their Z32’s, Nismo’s or stock 26/25’s voltage limit? RWKW would be helpful too.
Any help would be massively appreciated!!!
- RKaida
https://www.sau.com.au/forums/topic/82284-z32-afm/page/2/#findComment-1535769
To my understanding "supposedly" when you run out of resolution on twin z32, you'll need parachute to stop your car, but I have ran them out of resolution and I probably can do the fred flintstone thing to stop my car. Since then, I have the individual intake pipe velocity tested, and it was found that one tract was more efficient than the other, this is what is causing the anomalies in my AFM resolution.
So answering your question geeTR, you'll have to wait till I get new tracts made up and retune to precisely answer your question, other than that' I'm just about over the power fc and going full autronic. LOL
https://www.sau.com.au/forums/topic/82284-z32-afm/page/2/#findComment-1540508
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
