Hey guys
Tonite went down to calder as a last minute decision, Big thanks to Brisby who helped me with helmet and getting my car ready!
First run ran a 13.1 @110 mph, then ran a 13.0 @ 110 mph.
Then I ran a 12.9 @ 111 mph with 2.1 60 fts. Then ran a string of 12.875 @111 mph.
Final Run ran a SS ute and assasinated it with a 12.822@ 111 mph. 2.0 second 60 ft. Ran about 10 passes and won every one of them with consistent 12.8s! I was reallly happy and pleased with the result!
Its not bad for a STOCK DUMP PIPE AND STOCK CAT fitted car. It was close to a 12.7 so if I put a split dump and highflow cat on it, run about 15 psi, shud comfortably pull 12.7 with about 113 mph.
https://www.sau.com.au/forums/topic/82287-into-12s-again/
tops effort dude. gotta be happy with that. the dump will make a nice difference to the power and how it comes on, try and do it soon for some more zest. batmbl sells em for $400 which is a 3" split dump. id love to run 12 but i dont think it'll ever happen. jealous as :)
https://www.sau.com.au/forums/topic/82287-into-12s-again/#findComment-1492030
Hey guys
Thanks for the kind comments! I must get a dump pipe for the car, its essential!! High flow cat too should improve power as well!
There was another white R33 that I know of there tonite, GT2540, powerFC,all the usual with 240 rwkw and he was running on Mickey Thompson 15 inch FULL slicks - ran a 12.7 @110 mph.
https://www.sau.com.au/forums/topic/82287-into-12s-again/#findComment-1492052
The car was amazingly consistant, and damn quick considering whats done to it:thumbsup:
That poor owner of the other white GTST, it was his first go with mickey thompsons and the last minute clean up of the tune resulted in pinging which meant he wound ignition out of everywhere to try and stop it...that combined with the haywire final drive now because of the huge diameter mickey thompson radials...well the car was running slower then its previous times with old tune and road rubber. Poor owner must have felt as though he had been kicked in the teeth to go serious in the rubber dept and run slower:(
...and for gods sake get some tyres that smoke when you do 15sec burnouts:)
https://www.sau.com.au/forums/topic/82287-into-12s-again/#findComment-1492072
Think i saw a few runs of yours before you left, some nice times mate well done.
I was there for the first time last night and had a great time. Unfortunantly got there pretty late (7:30ish) due to work and traffic conditions etc but still got in 6 runs. Cant wait to get out there again and try improve my times.
Best time of the night for me was a 13.8 @ 107 with a 2.25 60ft time.
Best 60ft time for the night was a 2.17, however i think i rode the clutch abit too much cause it starting slipping in 2nd gear (i think, cant remember exactly was too caught up in the moment), ended up hitting rev limiter etc slowing me down and only managed a 14.0 @ 103. Ive got a brass button clutch so thinking it just got abit too hot and slipped??
All my runs ended up being in the high 13's area, hoping with a better 60ft time next time might be able to bring that down to mid 13's or perhapes slightly better! With a 107 trap speed that should be possible?
Was running 10psi all night, cooler, exhaust (stock dump), safc, ebc.
Had a mad time and cant wait to do it again, hopefully meet a few of you other skylines lads next time.
https://www.sau.com.au/forums/topic/82287-into-12s-again/#findComment-1492522
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
    • More so GReddy oil relocation kits, sandwich plates, etc. all use 10AN fittings. And same, I've only used 10AN and my car sees track work (circuit, doing laps, not 10 sec squirt business).
    • street use or race track, what hose size and why? what factors change with the hose size options ?   see most comon is an10. when you see most oem external coolers are closer to an12? does high volume oil pump like nitto need an12 or 10 be just fine
    • The rod I was moving left and right you can see looking from the passenger side floor up into the center console.  IMG_8095.mov
