hey guys this has probably been drilled to death this topic, just want to know if anyone knew what bov will easily hold 18 - 20psi without leaking, and is preferablly plumb back, is the greddy type s any good cos to me it just looks like the stock one, what about the hks ssqv? the car is going to be a drift car soon, is it necessary to put a bov on? will pluging the hole up do any harm to the turbo or the engine?
regards luke
https://www.sau.com.au/forums/topic/82311-wat-bov-wll-hold-18psi-20psi/
  • 1 month later...
the only time the factory bov MIGHT have a problem is being able to "VENT".
say you have are making a shit load of power using a large turbo which is gulping in masses of air... then during gearchanges, the sotck bov might not be able to "VENT" enough air and you will have reversion.
but the bov doesn't leak or open.
as stated above... it has a spring pressure, PLUS, even boost pressure on both sides of the diaphram.
well what can my problem be if its not the bov, when it was getting dynoed they could not hold 18psi at all it would spike there then drop to around 12psi, what could be causing this but a leak as they checked all the intercooler pipes for leaks and they said there was none, could my actuator be stuffed? i just blamed it on the stock bov because its the only part of the pipe work air can escape. my turbo is a highflowed job and should hold 18psi??
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
    • Well the articals keep saying a Q50s (Skyline in Japan) with a new Manual gearbox. I like the talk about the new looks with the round tail lights. I hope they bring back the retro look like they did with the Z
    • Off the back of feedback we have decided to mix up this next Motorkhana at Avalon to have some targeted skills practice for beginners to advanced. Saturday 6th September 2025 8:30am Capped 26 entries Standard Entry Fee: $89 Members Entry Fee: $55 (SAU Victoria Only) Entries Close: Friday 5th February  Where: 55 beach road Avalon. https://maps.app.goo.gl/HNUE3EuNue3sJxh38 Entries: Limited to 26 entrants (Passengers allowed over the age of 14 with a signed disclaimer and same safety gear) Disclaimer: Download  Please electronically sign and email to [email protected] or print and hand in and Driver Sign In. To compete in this event you will require A valid  AASA General Speed licence or (Day license via the AASA Website for $50) MA Licenses are no longer accepted by AASA https://aasa.com.au/  A helmet, long sleeve clothing and a 1KG mounted fire extinguisher recommended (But not Mandatory). Further details within Supp Regs on the enty link. Entry Link > https://www.sauvic.com.au/entry/deca/20250906 You can bring and have a passenger in the car but they need to comply to the same safety and clothing as driver. Bring your car and get to battle others, win, lose or draw. I can guarantee you will have lots of fun. Any questions email [email protected] Entry List: 1.Anna S 2. Luke S 3. Jesse Givens-Lamb 4. Luca Stamatescu 5. Madeleine Stamatescu
    • Wanna rewrite all of that in, say, 2 or 3 separate sentences, so that we can read it?
