hey
Can everyone post their pictures of R32 GTR's (preferably gunmetal grey) with R34 GTR rims on them. Im thinking of getting some but want some more pics because they cost heaps !
What does everyone think of R32 GTR's dumped with no wing and R34 GTR rims ?
Thanks
Nah! you don't wanna do that. 'cause then yours would look like mine (only lower and without a wing) lol!
i've got a gunmetal R32 GTR with R34 rims and i reckon it looks awesome eh... personal tastes though.
Amaru - don't you have scrub issues on the front during high speed cornering on mountain/etc roads? although mind you, you are in rather flat canberra  :)
If you think Canberra only has flat roads, you dont know where to look ;) Theres plenty a twisty winding mountain roads through forrests etc.
And nope, had no scrubbing issues :)
