  • 1 year later...
Just take it to any big panel beater shops, they can tell you if anything wrong, if u lived in VIC i could of told u a place but you don't so i really don't know, if u live near liver pool i could tell you my uncles mechanic shop he might tell ya what wrong, and he might tell where to go for repairs just PM if u want his location
i agree with trust33, check the hub. Exceller Steering would be my choice to check this kind of problem. This place is also one of SK recommended installers for his suspension groupbuys. They are located in Bankstown.
Like tdsepco said "don't stress - get some more advice. I race these things and have crashed one big time in the front. Even then the chassis was only slightly bent and I had it straightened. Every thing else in the front end bolts on and off - top/bottom arm, castor rod tie rod etc. if any of these bent you will chasing problems forever. Bit are easy to find and relatively cheap (on SAU) and not too bad from wreckers. Sometime all bits around from someone's half cut project.
Same goes for back - but heaps more moving suspension components. V V unlikely chassis bent - just some of the bits.
Suggest go to best frontend/wheel alighner you can find....pay for basic wheel align and hopefully they will tell you exactly what is wrong and what take to fix it.
Good advice may seem expensive first up, but WILL save you $$$$$$$$.
Kerry
apologies for the resurrection as well but i am looking to purchase a gtr that has had a front end collision with a high kerb....just under the intercooler....the impact has sheared off the 2 castor rods and pushed one wheel far enough back in the wheel arch to bend the trailing edge or the guard by about 2"
now the $64 000 question......do you reckon this would have bent the chassis or is it likely to be repaired with bolt ins??
now i know you guys don't have a crystal ball,but i am looking for suggestions re the chances of chassis damage...likely,maybe,definately,unlikely,etc
am i likely to be able to verify anything visually if i jack it up and take a decent butchers or am i wasting my time looking??
cheers guys
do you know any contact details for these guys mate?
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
