Hey guys
I have currently
a 3 1/4inch exhaust with highflow 3 inch cat
CES racing split dump to cat
and a hyper medallion muffler
i went down the quarter as some of you might be aware of
and, i could not hear my car at all, and was relyin on the feel of the
engine when to change .
couple of my shifts were a bit late and lost time .
i was wonderin what would be the best option to get a louder and nice note on my exhaust.
i dont want it heaps loud, so ya can hear me from 5k away .
i have heard most skylines around and they have a nice tough soundin exhaust.
Any help or ideas would be much appeciated.
And would still like to keep it legal, or close too it .
THanks
Barret
https://www.sau.com.au/forums/topic/83021-want-a-nice-soundin-exhaust/
I have a 3" turbo back (with split dump) and high flow cat with cannon that got me a defect at 98dB. It was very drowny but could hear it all the time. After the hi flow resonator, it was still loud but not drowny in the cabin and then with the silencer, the car runs and sounds like stock (but its removable)
I can send ya mp3's of the car's sound. I'd say the tone is made by the cannon.
I've founded out in cars that I own, not to use SS as it produce more noise in the higher frequency range, and titanium exhaust goes higher. So just the plain old mild steel produces a decent exhaust note with out the associated reverberations of thin metals. I'm currently running a 3.5 to 4 inch exhaust, yes, it weird but It isn't that loud until I really guns it, and then you can point me out from 2 suburbs away, but the things is at idle it's really quiet.
where do ya get the noise testing done.....so is it better to go a stainless steal one or another metal for in the dump pipes??
i want the performance and sound same as bazr33
Give it shit past the cops, i'm sure they will be more then happy to sound test your exhaust, dogs. :P
Why would you floor it past cops, thats asking for trouble in any car, its as if saying im a wanker, please pull me over. Just drive normally, withing the limits, as you should be doing.
anyways, does your exhaust have a flange for just the muffler? jump under the car and have a look, if it does, unbolt it. take it off, and start the carup, see what sort of noise it makes then go from there.
My r33 is a bit loud, not heaps tho, i have a 3" cat back, and from the resonator it goes into 4" pipe inthe the muffler out into a 6" tip, godamn !!!! lol. Its how i bought the car, and sounds nice, i know a dump and hiflow cat will change the sound very little.
But try unbolting ur muffler :blink:
If you are trying to get a louder exhaust to know when to change gears on the drag strip, I think you are barking up the wrong tree.
It is a bit hard with the helmet on, but if you keep a steady on the tacho it shouldn't be too hard. At worst, lash out and buy a shift light.
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
