last week my boss was driving a silvia which was doing compliance in a workshop on tokin hwy ..then ..one wheel just went off .. he nearly got an accident with other cars ,, but  lucky he drove the car to the side of the road... but the one side of the  front wheel , disc ,hub, everything just damaged....
wat a dodgy workshop...
I seen a silvia on the mitchell fwy last week with a wheel off................ :D
  • Replies 87
I can tell you now don't say the workshop was Dodgy as I know who you are talking about, I picked it up off the Freeway and I know the condition most 15 year old cars that are coming in to start.
Have a 50,000 yen car sitting around for god knows how long with odd wheels and most are missing wheel nuts to start, I put the wheel back on and those old Lotus Style wheels are prone to the problem as you cant get a decent grip on the nut.
It is nothing to do with the workshop it was one of those things that happen, it happens to a lot more cars then you think.
I can go on all day about the workshops who do "DODGY" work but when they lose their RAWS or backyard business I will highlight them then, DPI are investigating a few at the moment and I would be worried if they did my car as DPI will call you up and tell you to have the car re-inspected at Welshpool.
yeah i think u r right, most of the 15yr old car's condition are terrible...
but i'm just wondering how they can pass the dpi inspectioin if they can do nothing with the wheels or other stuff that's most important for drivers safty?.
or as i think ..the workshops should refuse to do the cars which can't be fixed or with big safty problem...
if they knew the car got problems like the wheel may come off then they still doing the car without fix up the problem....
Problem is with the wheels the car is put on hoist to check brake lines so no need to remove wheels bit if required only one is removed and all wheel nuts were loose on the Silvia, last car that this has happened to down south was straight from the panel shop and they admitted they were at fault (it was a Landcruiser and it made a mess).
Also when it comes to what to do and what not to do is you only do what the owner tells you because if you do something he doesn't say to do he wont pay for it and how much time do you spend on a car and not charge for it, I know it is only wheel nut but you have to stop somewhere, you can suggest what should be done but if no body listens you don't bother after a few cars.
I have refused to do a few 15 year old cars and I personaly wont do any now as I cant tell a guy it cost's $5,000 to make this R32 road worthy.
just confirmed the car i was saying was happend on orrong road in welshpool..
but i think u r right
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
