Full Rebuild, with most receipts done 3000k's ago.
JUST ABOUT EVERY GASKET REPLACED
FUEL INJECTORS TESTED AND FLOWED
BLOCK ACID WASHED
NEW WELSH PLUGS
ARIAS 87MM FORGED PISTONS
HONED AND BORED 40 THOU OVERSIZE
MATCH PORTED MANIFOLDS
NEW DRIVE AND CV BOOTS
STAINLESS DUMP PIPES
STAINLESS FRONT PIPES
NISMO N1 TURBO'S..RATED 400HP EACH
NISMO N1 OIL PUMP
NEW CRANK ANGLE SENSOR
OS GIKEN CAM GEARS
OS GIKEN TWIN PLATE CLUTCH
LIGHTENED FLYWHEEL
HKS POD FILTERS
HKS BOOST CONTROLLER
HKS TRIGGER SYSTEM
TRUST INTERCOOLER
ARC BOV
GATES RADIATOR HOSES
GATES TIMING BELT
NGK IRITOP SPARKPLUGS
REMOTE OIL FILTER RELOCATOR
REMOTE OIL COOLER
HKS FULL TRIGGER SYSTEM..BOOST CONTROL
APEXI REV SPEED METER
IN DASH DVD PLAYER
IN DASH CLARION LCD PULL OUT SCREEN
12" SUB AND AMP
RELOCATED AIR CONDITIONER MODULE IN GLOVE BOX
VEILSIDE GEAR KNOB
RAZO PEDALS
BLITZ BOOST GUAGE / TURBO TIMER
PIVOT SHIFT LIGHT
ISOTTA STEERING WHEEL
SPEEDO CHROME SURROUND
RETRIMMED DOORS
GENUINE APEXI MAGS 17" X 9"..RARE AS
NISMO BOOT LIP
N1 FORNT BAR SLOTS
TRIAL SIDESKIRTS
BOMEX REAR PODS
The cam gears are still not set as I need to get it done properly so there is still heaps of power to be made in tuning.
Feel free to email me for more pics..motor etc
Edited by ricknismo
https://www.sau.com.au/forums/topic/83223-32-gtr-with-the-lot-and-a-large-coke/
  • 5 weeks later...
  • 3 weeks later...
rick just to clear something up that might scare off potential buyers, 40thou over bore is 87mm pistons, its probably just a typo but it stands out to those in the know.
Good luck with the sale one of the best value for money GTRs I have seen on here is a while.
Daniel
    • I'm working on the assumption that our friend Jasmine here is a Russian (or, possibly Ukrainian) spammer/spambot, based purely on the number of such that I have been having to neuter in the last few weeks. IP address for the OP above was in WA. But that could have been via VPN. Posting at quarter to 4 in the morning is a good sign of being from somewhere in Europe. The last Jasmine that I kicked in the cooch was IP addressed in Ukraine. Even that could have been via VPN, and the bitchbot could have been from Russia, Serbia, China or anywhere. Regardless, was a spambot, so I killed it with fire. The fact that our new friend Jasmine here did not respond in any way to my tart query strongly suggests to me that this OP was just the establishment phase of a user able to be activated for spamming in a week, or 3 or 10.
    • The stock manifold is "mostly" divided. The divider actually has a notch cut out of it where it would meet the divider on a twin scroll housing. I have no idea why. But whatever the reason, it would cause some cross talk when used with a twin scroll housing. People do put twin scroll housings onto that manifold. But I'm of the opinion that proper twin scroll internal gating is...not really possible at this scale. You'd be throwing good effort (ie $$) after bad, when you really should be doing something else. Notwithstanding that.... I am not sure what the idea that you are floating has to do with the difference in comp cover position caused by the highflow using a shorter length core than the stock Hitachi one. Can you clarify what you meant?
    • Majority of regulars are > 30. We all act at least 50. Definitely not friendly as we're all grumpy. 😛
    • haha all good, also he took it out to Luddenham last year with me, on a 30+ degree day too.  Car did not explode.
    • Open minded? Have I stumbled into Hongdae?
